Apexy PowerFC
Apexy PowerFC
Сообщение MMX » 01 июн 2018, 09:05
Постараюсь собрать в этой теме как можно больше информации по настройке Apexy PowerFC.
Re: Apexy PowerFC
Сообщение MMX » 01 июн 2018, 09:06
Калибровка мап сенсора
____________________________________
Calibrate any MAP sensor to your Power FC
I had to dig a lot to get this info, so I thought I'd share.
If you are using a non-standard MAP sensor (something other than the factory gen3 or the Apexi), you need to calibrate it to work with your engine. I am personally using the Greddy MAP sensor that was included with my electronic boost gauge. No need to spend the extra $$ on another one!
These instructions assume that you have the FC-datalogit.
The two factors are scale and offset. Just so you know what we are calculating:
a line can be calculated by: y = mx + b
Scale: defines the slope of the voltage of the MAP sensor. ("m")
Offset: the y intercept. ("b")
Instructions:
Turn key to "On" position but do not start the engine.
Start with 41,800, 0 settings (scale, offset)
Go to the "Map Watch" screen, and add "Advanced PIM".
Note the PIM at atmospheric pressure (eg 9,950) = PIM0
Use a pressure pump to supply 100kPa boost and note the PIM (eg 20,050) = PIM1
Now calculate the new scale factor:
SF = 41800 x 10000 / (PIM1 - PIM0)
SF = 41800 x 10000 / (20,050 - 9,950)
SF = 41386
Now, plug in the new SF, then adjust Offset so that atmospheric - PIM = 10,000 and boost should also be 0.
Please note, I have not yet tried this myself. However, the logic seems to flow and looks right to me. I hope to use this formula this weekend.
I hope this is helpful for you.
Re: Apexy PowerFC
Сообщение MMX » 07 июн 2018, 08:48
Unit Information:
What does the unit do?
The unit is a full replacement ECU for your factory computer. It is not a piggyback system and as such allows full control of the engine and computer controlled systems. It comes with a base map of your cars computer with base map tuned for basic mods such as exhaust, boost controller, air filter upgrade. "The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path." - www.apexi-usa.com
What cars is the PowerFC supported on?
Standard Versions
Honda Civic Type R 97/6-98/8
Honda Integra Type R 95/9-01/6
Mazda RX7 Series 1-3 91/12-95/11
Mazda RX7 Series 4 95/12-98/12
Mazda RX7 Series 5 99/1-00/9
Mitsubishi Evo V 98/1 - 98/12
Mitsubishi Evo VI 99/1-01/1
Mitsubishi Evo VII 01/2 - 02/3
Mitsubishi Evo VIII (EVO VII PFC + 4E73G013 EVO VIII Harness) - VIII MR might not be supported
Nissan RPS13 (Black Head) 94/1 - 96/7
Nissan RPS13 (Black Head) 96/8 - 99/1
Nissan RPS13 (Red Head) 91/1 - 93/12
Nissan S13 Red Top 91/1 - 93/9
Nissan S14 93/10 - 96/5
Nissan S14 96/6 - 98/12
Nissan S15 99/1 - 02/7
Nissan Skyline BNR32/BCNR33
Nissan Skyline BNR34
Subaru WRX Ver1,2 92/11-96/8
Subaru WRX Ver3,4 96/9-98/8
Subaru WRX Ver5,6 98/9-00/7
Totoya Mark II, Chaser & Cresta JZX100 manuel 96/9-01/7 1JZ-GTE
Toyota Altezza SXE10 01/5 3S-GE
Toyota Altezza SXE10 98/10-01/4 3S-GE
Toyota Celica ZZT231 99/9 - 2ZZ-GE
Toyota Mark II, Chaser & Cresta JZX100 Automatic 96/9-01/7 1JZ-GTE (Mark II only to 00/9)
Djetro Version
Mitsubishi EVO V CP9A 4G63 98/1-98/12
Mitsubishi EVO VII CT9A 4G63 01/2- 02/3
Nissan 180SX RPS13 91/1-93/12 SR20DET (Red Head)
Nissan 180SX RPS13 94/1-96/7 SR20DET
Nissan 180SX RPS13 96/8-99/1 SR20DET
Nissan Silvia PS13 91/1-93/9 SR20DET(Red Head)
Nissan S15 SR20DET 99/1-02/7
Nissan Skyline BNR32/33 89/8 - 98/12
Nissan Skyline BNR34 99/1-02/8 RB26DETT
Nissan Skyline ECR33 Special Bundle Kit (See here)
What cars is the PowerFC not supported on?
Vehicles such as the Nissan Stagea are not supported however the Stage features a Skyline engine (either rb25de, rb25det, rb26dett) engine and standard computer, so a suitable PowerFC for same engine year/model *should* work fine engine/computer.
The Apexi PowerFC is purely an injector and ignition driver but is it suited around specific car models to suit their sensors and control signals. It is possible to make it work on other unlisted models or cars but it would require extensive re-wiring and/or sensor matching to make it work.
Vehicles such as the Nissan Skyline R33 GTST that feature the Active-LSD or A-LSD and SLIP function (lights on the dash and vspec diff) will suffer A-LSD compatibility problems. The car will operate correctly and the diff should as well however you will experience "A-LSD" error/failure intermittently. To date there is no known solution for this problem. It appears to be only present on the R33 RB25DET. There was a limited run of R33 known as the GTS25TML spec which is the M Spec with Active LSD. The diff is a skyline GTR vspec diff, electronically controlled LSD instead of a normal R33 diff. It features the same finned cover and A-LSD function as the Skyline GTR. The A-LSD and SLIP functions in the Skyline GTR with the Skyline BNR33 PowerFC work fine, only the ECR33 with ECR33 PowerFC is affected. See here for some discussion on the topic.
There is now an unofficial Fix for the A-LSD problem found in the ECR33 Skyline. Please click here to view how to fix it; https://www.sau.com.au/forums/topic/107 ... active-lsd
What does the unit look like?
The PowerFC looks and is usually in the same ECU case as the standard ECU for your car. This is because it needs to use the same car loom adapter, same brakets etc so its usually the same physical shell & bolt holes for the ECU braket. The hand controller is a lightweight and ergonomic device with a backlit LCD screen. The screen is larger enough for most tuners and owners to use and operate. It includes enough functionality from the 4 main buttons and PREV and NEXT to control the car, make changes, update the tune etc. I would recommend all owners buy the PowerFC with the hand controller - It is very basic without the hand controller and you can't update/change anything.
What are all the menus and functions on the unit??
Here is a function list of all available options from the Hand Controller.
This is for every PowerFC version so you won't have some of these on your Hand Controller.
Note: Some items are not avaiable on various units (ie: PimVolt only on DJetro and Map Sensor versions)
Note: Some factory items do not work - Airtemp on R33 GTST
MONITOR
AirTemp - Air Temperature
Airflow - Airflow Meter Voltage
BatVolt - Battery Voltage
Boost - Boost Pressure (Bar)
Eng Rev - Engine RPM
IgnT Ld - Ignition Leading (Rotary only)
IgnTmng - Ignition Timing
IngT Tr - Ignition Trailing (Rotary only)
InjDuty - Injector Duty
Knock - Knock Sensor
PimVolt - Map Sensor Voltage (DJetro only)
Speed - Speed KM/H
WtrTemp - Water Temperature
SETTING
Acceler. - Acceleration Enrichment
Airflow - Airflow Meter Voltage Table
Cranking - Cold Start Cranking Table
IGL Map - Ignition Leading Map (Rotary only)
IGT Map - Ignition Trailing Map (Rotary only)
Ign Map - Ignition Map
Ign/Inj - Ignition and Injection Temporary Adjust
Inj Map - Injection Map
Injector - Injector Latency
Pim Volt - Map Sensor Voltage Table (Djetrol Only)
Rev/Idle - Rev and Idle Settings
Wtr Temp - Water Temp Correction Table
ETC
Prog. Version - Display PowerFC and Hand Controller version
Sensor/SW check - Sensor check page
Function Select - Function Select
02 F/B Control - O2 Sensor Feedback Control - Open/Closed Loop
Airflow Warn - Airflow Meter Warning - 5v Peak (Engine check light)
Boost Cntl Kit - Apexi Boost Control Kit
Idle-IG Cntrl - Map Sensor Idle Logic (Djetro only)
Injector Warn - Injector Warning (Engine check light)
Knock Warning - Knock Sensor Warning
LCD/LED adjust - Backlit display contrast adjust
All Data Init. - Reset to Factory Defaults
Apexi went to great lengths to ensure you could control everything that a tuner would need with minimal fuss.
The interface is very intuitive and easy to use. It appears as they didn't opt to include un-needed/un-necessary things such as monitoring oil pressure from the hand controller, oil temps, and other sorts of "nice to have features".
As these would add development cost, extra sensors etc. The unit is a very efficient plug and play unit for a very cheap and affordable price. Extra junk just adds development cost, which increases the price. So basically everything you need is via these menu's.
Re: Apexy PowerFC
Сообщение MMX » 08 июн 2018, 08:42
Is there a menu roadmap?
For a menu road map check out the following picture, coutesy of Autospeed:
Does the unit work on my N/A car?
It has been rumored the work with unconfirmed reports. The model however is still suited for the turbo version of the engine so timing, ignition, maps etc may be unsuitable. There are a few N/A PowerFC versions for the Honda etc so they do exist, its just more common for the turbocharged models.
Does the unit work on manual and auto cars?
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
How much does the unit cost?
The unit currently retails around $900 AU delivered from Japan for a new unit. However as Apexi have altered their production plans this only applies to some select models. Other models must be sourced 2nd hand from forums, ebay, other members etc. For AP Engineering models they are more expensive as they are a custom made model and retail is around $1500 AU or even higher. Recent pricing indicates around the $920 mark is more realistic. There are some workshops or resellers that list they have the "Australian" version of the Apexi PowerFC. This is simply the same PowerFC but sold with an Australian delear or reseller warranty. Normally your PowerFC needs to be sent to Japan for a warranty claim and/or testing. With an "Australian" version it can be done locally supposedely.
There are also unconfirmed rumors of the local distributors being able to supply the latest firmware for the PowerFC. To date the latest firmware I have seen on ECR33 is 5.11 which was from Mid Oct 2006 build. The price of the "Australian" PowerFC is somewhere near $1500 so its not even worth the cost, given the mean time between failure of the PowerFC's. Basically if it fails, you've done something wrong or have a dodgy wiring loom / hacked up loom.
Lately it seems everyone is cashing in on the "discontinued" situation that the PowerFC is in.
The main models are still in product, its just slower and takes longer to get one on order new from Apexi.
I would be careful in how much you pay for a PowerFC these days. I have seen upwards of $1600 AU for a used unit these days on Ebay.
The places I would look for 2nd hand PFC's would be your local car club, Ebay and Yahoo Japan auctions (lots on here usually).
There has been a recent update to the discontinuation of some PowerFC models since June 2012.
Apexi it looks like are now making some previously discontinued models. Examples of this includes ECR33 and ER34 powerfcs.
You can buy these brand new from most Apexi suppliers now and one that comes to mind is nengun.com which stock both models, brand new.
When I buy the PowerFC what comes in the box?
The current PowerFC comes with the following items
Apexi PowerFC ECU
Apexi PowerFC Hand controller
Apexi PowerFC Japanese Manual
Apexi PowerFC Japanese Warranty Card
Velcro Sticky tabs for use with the Hand Controller
This applies to new units purchased. Previously the older style new units were the main ECU only.
Some time around 2004 ish Apexi decided to bundle the hand controller and ECU as one main price.
Why would I want to buy a PowerFC?
There are many reasons for changing to a PowerFC the most common being to extract more power from the current engine setup. Your cars factory computer has many limits and conservative settings to ensure engine reliability and to ensure factory components do not have excess load placed on them. As you upgrade these components the factory computer will not retune itself and therefore you will not obtain your maximum benefit. You can reset your cars ecu (works in most Skylines) and it will relearn your engine setup and adjust accordingly but that is only basic tune settings. There are much more advanced tune settings available with the PowerFC.
Re: Apexy PowerFC
Сообщение MMX » 08 июн 2018, 08:45
Model Information
Is there an English manual? a PDF copy? English translation?
An outdated english manual (for the RX7) is available at English Commander Manual. Right click, Save as
The current Japanese manual can be found at Japanse Command Manual (updated) Right click, Save as
For a complete Japanese Manual matrix on the Apexi site go here: http://www.apexi.co.jp/manual2/pdf/torisetu_p_fc.html
Japanese Manuals (high quality PDFs)
Name Link
PowerFC Manual 3SGE Right click, Save as
PowerFC Manual RX7 Right click, Save as
PowerFC Manual Nissan (180sx, 200sx, GTST, GTR) Right click, Save as
PowerFC Manual Evo Lancer Right click, Save as
PowerFC Manual Evo Lancer DJetro Right click, Save as
PowerFC Manual MR2 Right click, Save as
PowerFC Manual 180SX Right click, Save as
PowerFC Manual SR20 Right click, Save as
PowerFC Manual Honda Integra Right click, Save as
PowerFC Manual Skyline GTR Djetro Right click, Save as
PowerFC Manual Chaser JZX100 Right click, Save as
PowerFC Manual Subaru WRX Right click, Save as
Re: Apexy PowerFC
Сообщение MMX » 11 июн 2018, 07:51
What model do I need? (Version Matrix)
Version Matrix
Version Alternate names? Input Type Extras
Standard LJetro or just normal PowerFC Airflow meter normal unit
Djetro Map Sensor PowerFC Map Sensor normal unit with map sensor input instead of AFM
Pro FC Pro - PowerFC Pro AFM Launch control (0km/h limiter) & Spark cut (instead of fuel cut) at limiter
AP Engineering AP Eng AFM usually These are remapped PFC's to suit extra cars (ie R33 RB25 GTST PFC remapped to suit R32 RB20 PFC)
You cannot mix and match models - Some cars only have access to some models etc. ie: There is no Djetro version for R33 GTST - There is no Pro version of Evo 8 etc. Apexi release some models in all 3 flavours to suit the market (Skyline GTR gets all 3 options). Some models can be back ported to other cars ie: R33 GTR can work on R33 GTST so you can have R33 GTST Djetro (and Pro etc). Some AP engineering releases can be Pro versions too. There are some counterfeit FC Pro versions out there (buyer beware).
Click here to read up on the PowerFC Djetro Version
Click here to read up on the PowerFC Pro Verion
Click here to read up on the PowerFC AP Engineering Version
You should note that all models are now discontinued other than standard Ljetro versions. Apexi no longer make Djetro, Pro or AP Engineering versions. You need to source these models 2nd hand from Ebay / forums etc.
What is an "AP Engineering model" and do I need it?
"A.P. Engineering Original Power FC units carry the same functions as the regular Power FC units but have been specially adopted for use on car models that the regular Power FCs do not cater for. As they are an item outsourced from Apexi, their pricing is higher than the regular models." - www.greenline.jp. An example of an "AP Engineering" model is the PowerFC for the r32 gts-t.
AP Engineering versions are no longer available brand new. You need to purchase one second hand if you want to buy one.
What is the "D-Jetro" model and do I need it?
The D-Jetro Power FC units carry the same functions as the regular Power FC units but do not require the use of the factory standard air flow meter and use a mass air pressure sensor. Apart from the unit itself, use of the D-Jetro units requires additional parts that vary depending on the model." - www.greenline.jp The airflow meter (at least in the skyline range) does not pose a big restriction in terms of horsepower and one would doubt the use of the D-Jetro. If you really need massive airflow you can always change to 2 x Q45 Airflow meters and use those with the PowerFC. The skyline series are optimized for closed loop operation with an airflow meter.
The Djetro version has a few caveats you should know about before you consider using it
Careful placement of the map sensors in multiple throttle body systems
With multiple throttle bodies, such as the Skyline GTR RB26 or the Pulsar's GTI-R SR20 multiple throttle bodies can have bad side affects when using a map sensor system. Consideration needs to be taken into account when placing the map sensor (or map sensors) for the Djetro system to avoid idle problems on multiple throttle bodied engines.
Tuning will take considerably longer
It will take considerably longer to tune a Djetro PFC over a normal LJetro PFC. This is because all of the work has to be done from scratch instead of just doing the main bits in the AFM/LJetro version. You should discuss this with your tuner and find out the total cost for a Djetro tune.
What is the "Power FC Pro" and do I need it?
The Power FC Pro Spec.CPU has been designed for drag racing use. These units have two additional functions over the regular units: 1. Ignition cut used for rpm limiter - Regular Power FCs cut fuel feed when the preset revolution limit is reached. At high rpm, there is the possibility of knocking when the fuel is cut in high-powered cars. The Power FC Pro CPUs cut ignition at the rpm limit to prevent the knocking that could potentially destroy the engine. 2. 0km/h rpm limiter setting - Allows for the setting for an initial rpm limiter that is active whilst the car is not in motion. This allows for mainting a rpm level for consistent launches.
PowerFC Pro versions are no longer available brand new. You need to purchase one second hand if you want to buy one. There have been reports or rumors surfacing of fake PowerFC Pro units that are just the normal standard versions.
The true PowerFC Pro versions have some unique features which give them away.
Have a look at What does the PowerFC look like inside? to identify what a PowerFC Pro version looks like.
The dead give aways are the older style main board with the top mounted expansion chip (same as AP Engineering).
There was a common assumption that a PFC with an "FC Pro" sticker on the case, meant it was a PowerFC Pro unit. THis is NOT correct. The "FC Pro" sticker identifies that you can use it with Apexi's Power Excel Software, nothing to do with the PowerFC Pro (spark cut and 0km launch control model). I have no other information on how to verifiy if its a true legit FC Pro unit other than starting the car up and checking ETC, VERSION before buying.
There should also be a sticker on the main ecu which would read something like "RB25PRO1" or "RB26PRO1". Under ETC, VERSION on the hand controller you should see a similar version string "RB25PRO1" or "RB26DETTPRO1" etc. It should definetly have PRO in the version string - There have been reports of people reflashing the Pro hand controller to normal FC code (don't see why u would?) Be sure to double check before you buy it to make sure its a legit PowerFC Pro version.
For some more discussion on the this topic check out gtr.co.uk;
Power FC Pro identification help
What does the "FC Pro" sticker mean? Why is it there?
The first generations of PowerFC units were only tunable by the hand controller.
You weren't able to plug in Datalogit or Apexi's Power Excel software.
Then some time later, Apexi changed the main board logic and control and included the ability to tune via their Power Excel software (and datalogit).
So customers could work out what units were able to be tuned by Apex and the software they started placing "FC Pro" stickers on the case.
This would allow Apexi and a customer to work out what unit they should purchase so their local Apexi dealer could plug it in and tune away via Power Excel.
How can I translate/check my serial number - What does each part mean?
There are two issues here
1. No ones gives a rats ass about Power Excel and most use Datalogit
2. Most people (including me) assume that "FC Pro" means its a PowerFC Pro unit
So, if you see a unit with an "FC Pro" sticker, it means absolutely nothing.
There are a number of units, that are tagged with an "FC Pro" sticker.
The build dates (serial numbers) are - 05/1996 till 1997
So units in the range like PFC RB26 9608 XXXXXX up until PFC RB26 9800 XXXXXXX - it will have an "FC Pro" sticker on it.
This would apply to RB25, RB25, SR20 etc - all mainstream units.
There are two distinct serial number schemes used in the PowerFC model #'s.
First generation is
YYMM-XXXX
Where;
YY is the build year
MM is the month
XXXX is the unique item #
Second Generation is
###-XXXX
Where ### is the batch build number, so 000 or 010 or 020 (ie batch build 010)
AP Engineering units are;
YY# XXXX
or
A XXXX
Nissan Skyline - Old Version (YYMM style serial #)
AP Engineering RX7 - Old Version (A style serial #)
& AP Engineering AE86
Nissan Skyline - New Version (### build style serial #)
& Subaru WRX - New Version (### build style serial #)
Nissan Skyline - FC Pro Badged Version (YYMM build style serial #)
See notes below for FC Pro
Another oddity we noticed is that all the 1996 built Skyline RB26 models (414-N001) I've seen so far have a FCPro sticker but a regular firmware version. This conincides with what we have seen in the wild, where a number of PowerFC Pro users, report they have standard PowerFC unit - but its badged as a Pro version. So if you buying an FC Pro version to suit Skyline RB26 - Make sure it doesn't have serial # -> 96??-???? as its probably a normal version
Thanks to Andre from FC Tune for the version string and info
Re: Apexy PowerFC
Сообщение MMX » 15 июн 2018, 09:38
What other optional parts are available for the PowerFC?
Here is an almost complete of optional parts for the PowerFC.
Note they do not work or plug into all models, some parts are Djetro only, some are Ap Engineering only etc.
Hand Controllers
Name Part No
Hand Controller (Old Style (To suit ENGINE MODEL STYLE PFC - IE: PFC RB25 or PFC RB26) & AP Engineering old style) 415-N001
Hand Controller (new Style (To suit CAR MODEL STYLE PFC - IE: PFC ECR33 or PFC GTR33L) & Multiversion hand controller) 415-X001
Hand Controller Toyota 415-T001
Hand Controller Toyota (JZZ30 only) 415-T003
Hand Controller Extension Cord (Make your own)
Name Part No
Hand Controller extension cord 60cm 415-XA01
Hand Controller extension cord 3m 415-XA02
Boost Solenoid Kit (To read and display Boost on the hand controller)
Name Part No
Apexi Boost Sensor (Boost Control Kit) 499-X001
Apexi Boost Sensor Harness (3 pin PFC) 49C-A002
Apexi Boost Sensor Harness (5 pin PFC) 49C-A003
Apexi Official Software (not recommended)
Name Part No
Apexi FC Commander Pro software 415-X010
There are other optional parts avaiable you just need to find the part numbers.
In actual fact I recently brought the Boost Control Kit in parts and found it cheaper in parts, I guess this is becuase of the way its shipped in a medium box.
Is the PowerFC Pro Discontinued?
Apexi have discontinued the PowerFC Pro model which was the special version of the PowerFC that had IGN cut instead of Fuel cut and also had a REV LAUNCH function holding the rpm at a set value at 0km/h. For some cars the PowerFC Pro model exists (RB26, RB20, WRX) but for most models it has been discontinued. Apexi have not released any information as to why the model's have been discontinued or if there will be a new model coming out. Those customers who must have the Pro models should look for a 2nd hand unit instead.
For alternate solutions for "Pro" style functionality check out Apexi PowerFC Djetro PRO - Does it exist???
Hybrid Apexi PowerFC models and mix n match models, can it be done?
Whilst this type of work is possible and it can work there are some known gotchas and things that don't work so be sure to read it in full and understand everything before you go ahead and do it. Lastly there are some workshops that can do this for you, this is common for exmaple using the RB26 GTR PFC on the R33 GTST, there are workshops who can fit this and tune it for you. Some of the known gotchas are the 02 sensors, loss of VCT and AFM ramp tricks that are required to make it work.
It is in fact possible to interchange Apexi PowerFC models to suit other engines. That is to, rewire an existing model to work on another engine and loom. Below is a list of the combinations possible and how to achieve the goal of making it work. Please note this information is taken from the Forums are various peoples opinions and ideas, it is not %100 guaranteed nor have I tested each of these myself, so you've been warned.
Apexi RB25 PowerFC on RB20
To run the RB25 PowerFC you need to swap injector triggers for cylinders 4 and 6. This is wires 112 and 114 on the RB25 ECU pinouts diagram which can be found here. You also need to run larger than rb20 injectors. You should be able to swap to Rb26 440cc injectors without much fuss and this should work, providing you dial in the correct injector latency and correction (and use the resistor pack).
Apexi RB26 PowerFC on RB20
The traditional Ap Engineering RB20 model is in fact and RB26 model remapped to suit the RB20 loom and sensors. The main differences between the two is Airflow meter and 02 sensors. The RB26 having two, and the RB20 having one of each.
Two AFM:
If you are using two airflow meters you will need to run wiring for the second airflow meter manually as the RB20 loom only has support for one airflow meter.
One AFM:
If you are using one airflow meter you can simply parrallel up the airflow meter signal into the second input on the RB26 ecu. The ECU will average out both signals despite it coming from the same airflow meter to work out engine load (or airflow load).
02 Sensor:
The RB26 uses two 02 narrowband sensors to run in closed loop correctly. Simply parrallel up the oxygen sensor into the second 02 sensor input on the RB26 ECU.
Hybrid RB30DET
You can use any variant of the Apexi PowerFC on the RB30DET. It would be easier using one that suits the head you are using and loom. The likely recommendations for the RB30DET would be the RB20 or RB26 version. You don't need to worry about VCT with either of those choices.
Notes:
If you use the RB26 PowerFC on your hybrid or standard engine you have the best pick of the bunch. You have the following advantages;
Able to use two airflow meters when a single becomes a restriction Have access to the Apexi PowerFC Pro version Have access to the Apexi PowerFC Djetro version
Apexi PowerFC RB20 vs Apexi PowerFC RB25 wiring
Here are the main differences in the wiring loom for the RB20 vs RB25
Apexi PowerFC RB20 SENSOR SW CHECK
Apexi PowerFC RB25 SENSOR SW CHECK
Differences between RB20 and RB25 looms
Here is a version matrix for all the Skyline PowerFC's and their feature set
From here you can see the RB26 version is the pick of the bunch if you are going to run a different PowerFC for your engine/head combination. Choosing the RB26 version allows you to select
Djetro or Ljetro
Pro Version
Single or Twin AFM (if single parrellel up the single AFM onto both AFM inputs)
As an experimental branch I am trying to wire up and sell 26 PFCs to suit Rb20 and Rb25. This will negate the lack of production by Apexi/NEC and give Rb20/Rb25 owners a chance to still buy and use the PowerFC.
Re: Apexy PowerFC
Сообщение MMX » 16 июн 2018, 09:09
Apexi LJetro Vs Apexi Djetro - Whats the deal??
For some time this debate has gone on with various opinions and ideas with no real concrete evidence/proof or logic to back it up.
There are two distinct differences between the LJetro and Djetro PowerFC (and presumbably other LJetro/Djetro ECU's) and we will discuss them as this is a hot topic.
Having since worked out the mathematics behind the Load axis calculations for both the Ljetro and Djetro versions of the PowerFC I can show you how they are both calculated.
First we should look at each base model and how it works;
Apexi PowerFC Ljetro Version
Uses standard airflow meter
20x20 Load Map
Other addtional supported airflow meters (selectable on menu)
Apexi PowerFC Djetro Version
Uses optional supplied Apexi Map sensor
20x20 Load Map
Other addtional supported map sensors (selectable on menu with correct voltage and offset)
Both units are scalable upto 1100bhp with supported modifications, sensors, injectors etc.
i suspect the ljetro version was created first, and then Apexi following demand added the Djetro version for some select cars as they found customers were migrating to other ECU's to map sensor support.
Ljetro Vs Djetro Load Axis:
Both have arbitary values for Load indiciation, Djetro has higher RPM as its from RB26 Djetro
Airflow Meter Ramp:
Voltage Ramp for Airflow meter load signal. Infinitely scalable, as we can rescale any given airflow meter.
The most commoin airflow meters are supported out of the box, Z32, Q45 and Apexi Power Intake.
Seemingly all the Apexi Power Intake does it alter the ramp values, which should yield slightly higher airflow load values, which should drop them on the map 1.3rows if that, ever so slightly.
Map Sensor Ramp:
Voltage Ramp for Map Sensor. Each sensor has a single Offset and nothing more. Fixed offset value
Optional Map Sensors include GM5bar map sensor and Denso unit's also. The Apexi one is in fact a Denso unit. The only map sensor supported out of the box is the optional Apexi one (denso rebadged).
GM 5 bar and other sensors need their scale and offset placed into the PowerFC to work.
Apexi Ljetro Load Calculation:
LOAD = CORRECTION * (16384 * Airflow lookup(MAFSV) / RPM)
Airflow is proportional to RPM so this is why we are divisible by RPM.
We obtain MAFSV from our running environment.
We lookup the Airflow value from the Airflow ramp table (viewable by datalogit) and use this value.
We lookup the CORRECTION value from the Airflow corretion table, for 4.48v and higher my correction is 84%
ACR MAPN MAPP Rpm Load MAFS1 V MAFS2 V Inj ms Inj +/- IGN Dwell Boost Duty WtrT AirT Knock
0 11 14 4694 10725 4.705 0 15.568 256 21 51 -760 95 75 175 7
0 10 14 4591 10918 4.73 0 15.88 256 21 51 -760 95 75 175 4
0 11 14 4725 10915 4.745 0 15.952 256 21 53 -760 95 75 175 1
0 11 14 4950 10956 4.835 0 16.08 256 21 54 -760 95 75 175 3
0 12 14 5175 11121 4.9 0 16.528 256 21 58 -760 95 75 175 7
0 12 14 5202 11153 4.93 0 16.632 256 21 58 -760 95 75 175 7
0 13 14 5561 10997 4.99 0 16.464 256 21 62 -760 95 75 175 3
LOAD = 0.84 * (16384 * 3598 / 4950)
The answer gives us 10003.57 and we can see for load point 14 we have an Load value of 9642.
The load value for point 15 is 11571 so we place our load axis on 14 with a value of 10003
As we can see here the load will always increase as the engine speed increases.
More and more air comes into the system and thus airflow load will always keep increasing until redline.
There have been doubts over this as many people see bog stockish R33 GTST's drop to load points 15 and shoot across.
This is due to the fact they are maxing our the airflow meter at 5.10 or very close to.
The reason it drops to load point 15 is because the majority of them have airflow % correction somewhere near 80% for 4.48v and higher.
___________________________________________________
Appexi Djetro Load Calculation:
LOAD = Map Sensor Offset * Map Sensor(PIMV)
We lookup the Map sensor offset and use this value (viewable by datalogit).
We obtain PIMV from our running environment
BatVolt MAPN MAPP Rpm PIM PIM V TPS V Inj ms Inj +/- IGN
14.3 2 8 1515 6565 1.996 0.501 2.111 152 14
14.3 2 8 1499 6414 1.95 0.501 2.007 152 14
14.3 2 9 1536 6782 2.062 0.501 2.176 152 14
14.3 2 9 1529 6696 2.036 0.501 2.184 152 14
LOAD = 3289 * 1.95
The answer gives us 6413 and we can see for load point 8 we have an Load value of 5938.
The load value for point 9 is 11571 so we place our load axis on 14 with a value of 6681.
As we can see once pressure is fixed or doesn't increase any more, the load value doesn't.
This will result in a horizontal shoot across method once target boost pressure is reached.
This is because the Djetro version uses air pressure and runs a guesstimation method to calculate airflow.
As the engine speed increases more and more air comes into the system, pressure remains the same and the load axis remains the same.
The Djetro has two additional features which are;
IGN vs TPS correction
INJ vs TPS correction
These are there presumably to assist in correction for the throttle position sensor.
These will have an affect on the output figures but don't appear to adjust the load bearing.
These are much like Airtemp correction or water temp correction, they affect values but don't adjust load bearing.
Ljetro
Pro's
-> Out of the box, works great, plug and play nothing more to add/change
PR: This is suitable for the majority of customers
-> Supports factory airflow meters and larger models
PR: This is suitable for the majority of customers and tuners (less fiddling the better)
Cons'
-> Some tuners/owners believe the airflow meter is a restriction
PR: Turbocharged cars have a restriction after the compressor outlet, not before.
-> Once you max out the airflow meter it can't show any more useful load to the ECU
PR: Once you max out a given airflow meter, move to a larger unit with higher resolution.
If you stay with an airflow meter maxing out (stockish GTST customers) then you basically have the same
load bearing as Djetro customers. Once you peak or reach max airflow (the most the AFM can show) then Load doesn't increase anymore.
This is dead obvious for stockish GTST customers who do a map trace.
Djetro
Pro's
-> No air intake restriction
-> No airflow meters in pipework
PR: This can be helpful for large twin applications. It may also help avoid chuffing or compressor shuffling.
With correct pipework and bends you should be able to run twin MAF's or even a big single MAF relocated in the after FMIC pipework
-> Can't max out airflow meters
PR: This is a valid Pro. But once you max out any airflow meter simply change to a larger unit or more scalable unit.
Con's
-> You loose load point resolution once you reach target boost (horizonatal shoot across, as pressure never changes)
PR: This would be my main caveat of moving to map sensor system, the lack of tuning points, as the map isnt a 20x20 useable map anymore.
From time to time there are various rumours or confusion over specific ECU models. The Apexi PowerFC DJetro PRO does not exist for retail sale / standard production use. The Apexi drag car is believed to run a Djetro PRO version which gives it spark cut, 0kmh launch control and djetro. I believe Apexi have simply modified the mainboard firmware to include both chipsets, being Apexi they can do whatever they like.
There are two ways that I can think of to achieve this goal;
Apexi PowerFC Pro & HKS VPC (Vein Pressure Conveter)
The VPC is an old legacy HKS device which lets you run map sensors and emulate standard AFMS.
I dont think it is supported on the mainstream skyline branch but I have seen it for z32 300zx.
I have also seen someone run an rb26 Djetro PFC on a 300zx as they are compatible (with changes).
Apexi PowerFC Djetro & Gizmo Launch Interface
The Gizzmo launch interface is a spark cut / anti lag box which runs in parrallel of the 6 igniton drivers.
This provides on demand spart cut for anti lag launches and flat shifting.
Why buy a PowerFC? Aren't they discontinued????
As everyone knows the PowerFC's future is in doubt. Apexi have had some financial issues and now there are delays with ordering models.
Some units have been scrapped and wont be made anymore. But nevertheless the are still thousands of second hand units on the market.
There are still plently of tuners around and still plently of workshops who support it. I am even trying to resurrect the RB20/RB25 powerfc by using an RB26 PFC and a custom loom.
So needless to stay its not like all the PowerFCs in the market will magically vanish or disappear tomorrow so keep on 'trucking'.
There are however some alternatives to the PowerFC on the market and we should not be biased here, as that is not fair.
I'm a proven Apexi PowerFC fan but like any ECU it has downfalls and bad sides, most things do.
So let's look at some of the alternatives and how they compare;
Greddy Emanage
HKS FCON
Apexi SAFC & SITC
Motec M800
Autronic
Haltech
Wolf 3d
Remapped ECU
Link
Below is some brief ntoes on each of the units and my thoughts / knowledge on the them.
This is by far no means of a techincal comparison or tuners views on each of them.
You should ALWAYS discuss any ECU choices with your tuner before you even start.
Greddy Emanage
The Greddy Emanage is a piggyback system onto the stock ECU.
That is, its a generic remapper for stock ECUs. So if you have a GTR, GTST, Evo, Subuaru etc the emanage can sort it out.
Its a stage 1 interceptor which intercepts IGN, INJ, and all the main sensors to control the car and let you "tune" the main system.
The stock ecu is still present so complex things like 4wd, traction control, abs systems etc work just as normal.
The unit needs a main harness to suit your car but the unit is generic so you can sell (or buy it from) it to anyone.
Once installed you can make relevant changes as needed such as airflow meter changes, AFR tuning, IGN timing etc.
There are some limits into the size of the injectors you can run and other changes as its an interceptor but all in all a good unit.
I have never been a fan on a remapper/interceptor but if I was going to choose one, the emanage would be the one.
HKS FCON
The HKS FCON is by far one of the more advanced and suprior ECUS for the japanese domestic market.
This bad boy suports EVERYTHING known to man and more than you can poke a stick at.
AFMS, Map sensors, twin kits, everything is virtually supported and it includes a 32bit ecu with 32x32 map area.
The HKS FCON has its drawbacks however, in Australia only one place can tune the FCON which is BD4's in Sydney.
SO if you live in Melbourne, forget it you can't touch jack shit on the ECU. There is a graphical FCON unit but I dont think its the equiv of the PFC hand controller.
The HKS FCON is locked to the HKS pro writer software so you can touch it with laptop software of your own hacking. Tuners need to be official HKS pro tuners to get the software. So if there are local HKS FCON tuners in your area go nuts, get it and enjoy, but for most there are no local HKS FCON tuners so its useless. Much like a mines ecu, no local tuners. I would love to try out this ECU and see how far and how much you could tune it, but sadly I cannot as I am not a certified HKS tuner (haha).
Apexi SAFC & SITC
These two little brothers are like pea's in a pod. You cant link them together directly but they give a good comprimise for standard ecu owners.
These two mates are favourable among the Auto market which the PFC does not support Auto cars (well nissan anyway).
Running both of these lets you bend IGN timing to your hearts content and make the ecu think your AFM is drunk to get some more power in and out.
All in all not a bad comprimise if you dont have a choice or cant go for a good supported stand alone (ie: auto ecu etc).
Cheap, cost effective and works well. You will be limited by this setup so be careful.
Motec M800
Enter SATAN. The bad boy of the ECU market that dominates all.
The Motec is a complete stand alone ECU for any car, any setup, any scenario.
You can choose inputs, outputs, engine control, batch or sequential fire, anti lag, fuel or spark cut, complete map control and 3rd dimension selection.
There is nothing the Motec cannot do. It is mainly used for rally and race cars but can be used on a street car. This ECU costs a fortune and is the ultimate stand alone ecu.
I would not recommend it for a mild skyline but you certainly can use it, it will just cost a lot. There are lots of local tuners so that shouldnt be an issue and everything is supported.
Autronic
I do not have much to say about the Autronic as I know very little about it. As far as I know its a stand alone mutli-purpose ECU to suit most cars.
It has good local technical support and a range of tuners as well. I believe you have options of AFM or Map sensor and it also enters the 3rd dimension letting you tune in 3d via Throttle Position Sensor (maybe others too?).
The Autronic has things like antilag, launch control and a few other cool features so its not a plain vanilla ECU. This is aimed at race/competition cars.
Haltech
I know jack shit about Haltech
Wold 3d
The Wold 3d has been one of the older generation ECUs for generic cars.
It has been locally supported and developed in australia for some time now. I think you get the choice for AFM or MAP so thats a bonus.
The newer Wold 3d v500 has extensive support for most of the comon features and extra stuff most users need, they say it even rivals motec/autronic.
I dont see any issues with running a wold 3d, but like most ECU's you need to find a range of good local tuners to sort it out for you.
Remapped ECU
Running a remapped ECU is cool and cost effective. It lets you tune the stock ecu (providing its supported and doesnt cost a bomb) and gives you good bang per buck.
You can support almost anything within reason, such as larger AFMS, bigger injectors etc and still retain factory control.
The main issue with remaps is you cant adjust jack shit once its remapped and most tunes are expensive each time as they do a complete burn of the chip.
Ie; its not like they can just change timing via a hand controller each time. The user also has no control or real time interaction with the tune.
LINK
I know jack shit about Link
So there you have it, a quick glance over some of the more common ECU's and what they have to offer.
If you disagree with any of these comments, please send me a pm on SAU or email me (paul@paulr33.com) and let me know.
I am happy to correct any incorrect info, mistakes or bad opinions. If you have an ECU you think should be on this list let me know also.
What's the Apexi D1 Limited Edition Hand Controller?
There was a limited build run of approx 100 units of the D1 Limited Edition D1 style hand controller. This was a gold stylish hand controller and worked just the same as the normal hand controller units. I Suspect it was a plain run of X001 hand controller to suit most models as there was only 100 made. From all that I can see its simply a gold case - I have no working photos of the unit in action etc.
Special Thanks to Skylineowners for the picture.
If you have any working pictures or a copy of "ETC, VERSION" from this hand controller please send it through to my email address
I have the older PowerFC that did not come with a hand controller can I buy a new hand controller separate and use that?
You may be able to depending on the version of the ECU and hand controller. If the version between the ECU and Hand Controller is different the Hand Controller will boot up the Apexi logo and freeze. Take this as a precaution as a few people have experienced this. If you experience the hand controller freeze problem click here to get some help on it.
My Hand Controller freezes at the Apexi Logo. Why???
Pay attention to the version matching and you can't go wrong. Your local supplier can order the correct hand controller for you. If you can't find a supplier can source the older styler and newer style hand controller (N001 and X001) for you new at a new price. If you are after a 2nd hand unit you can try Yahoo Auctions, Ebay or even Jap Parts at
What's the new Apexi PFC EL Hand Controller and what is different?
Apexi have released a new version of the PowerFC Hand controller which is the Apexi EL PFC Hand controller.
The part no is 415-A030 and this is the new "multi-version" PFC Hand controller.
The new version is confirmed to suit all powerfc models including Pro, Djetro, AP Engineering etc (only exclusion is Toyota JXZ100 Auto)
It essentially looks like FCC3 with a different screen model. The original units had LCD (Liquid crystal display) vs EL (Organic LED).
The EL / Organic LED screen's are found in the Apexi AVCR, SAFC and VAFC controller so it should look the same as this.
The official version is FCC4 on the hand controller
Knock bar chart display in 4 channel view (prev only display as bar chart in 1 channel view)
English only text in ETC, FUNCTION SELECT (previously japanese characters)
Here is the official product - thanks Duncan from Skylines Australia
https://www.youtube.com/watch?v=jRcvmFWVk-8
Re: Apexy PowerFC
Сообщение MMX » 19 июн 2018, 08:56
Considerations before use
Does the PowerFC run the whole car or do I need controllers for... (Aircon, Lights, ABS etc...)
The PowerFC emulates all the functions that your standard computer did. This includes things like Aircon, Lights, ABS etc.
What ever your car did with the standard ECU, it will do the same with the PowerFC.
Does the PowerFC have limits?
The PowerFC does not have limits such as speed limiter or boost cut the factory ECU has to prevent engine stress / excess load. It has adjustable idle, rev limit and on-load idle. You can set your cars rev limit to whatever you like. 10,000rpm if you like.
There are no hardset limits in terms of power, killowatts, horsepower or turbo size etc its purely as good as your tuner. So if you have a good tuner then there is no logical/physical boundary etc. The Apexi 1200HP drag car uses a PowerFC for its main ECU (no surprise).
What are the basic mods I should have when I get my PowerFC?
You can fit the PowerFC whenever you like however a basic list of mods is a great start as you’ll get the most gain out of it from the standard computer
Full Exhaust 3" from turbo back
Boost Controller (Bleed Valve or Electronic Boost Controller - Or you can use the PowerFC boost controller kit)
Air filter upgrade / Pod filter or CAI setup kit
Upgraded Intercooler
How does the PowerFC compare with the Apexi SAFC, AVCR and other Apexi computers?
The Apexi AVC-R and SAFC are piggyback systems. The SAFC controls airflow voltage and fakes airflow voltage to the ecu. This makes the ecu believe more airflow is present and cranks up the fuel/timing thus resulting in more power. The AVC-R is a boost controller and not really a piggyback as such.
Apexi SAFC - Piggyback Fuel Computer
Apexi AVCR - Boost Controller
Apexi VAFC - Vtech and Piggyback Fuel Computer
Apexi Imoni - Diagnostics display from consult port
Apexi Multichecker - Diagnostics display from consult port
Apexi PowerFC - Standalone Engine Management
Apexi SAFC vs Apexi PowerFC, whats the difference?
My cousin Peter just brought an Apexi SAFC for his R33 skyline and he had it tuned and made 204rwkw. It cost him $300 and $250 for a tune. Most people simply assume you can make power and expect 220rwkw.
They will both make very close to the same amount of power if both have been tuned correctly. But clearly the PowerFC winds hands down if it has been tuned correctly and has a bulk of its load points tuned. If you have the IGN and INJ tuned in the low load / light load areas the car will feel much better to drive, response will be better and fuel economy better than the SAFC + stock ecu. The main difference is the PowerFC will support more mods and if tuned correctly will feel like a new car to drive.
Both are only as good as the tuner.
Car 1 - rb25det with SAFC
Car 2 - rb25det with PowerFC
The truth is that car #2 isn't likely to make twice the power as the ecu costs twice as much. It all comes down to tuning and how the car drives, average power is the key here. The engine should feel nice on throttle response (IGN timing), come on boost nice (IGN timing) and cuirse will with good economy (INJ tuning). I would expect the power difference to be 5 to 10rwkw at the most in the midrange and top end.
Distinct Advantages:
Adjustable IDLE
Configurable knock warning
Configurable injector warning
Configurable airflow meter warning
Airflow meter change support
Injector change support
Complete ignition map control
Complete fuel injection map control
No speed cut
no excess airflow cut (aka boost cut)
The main problem with an SAFC and increase power levels is that its still a piggyback and when you tune more and more, it's still a comprimise. As you try and lean it out more, it (the stock ecu) advances the timing as a result, which results in more detonation. The end result is it has to be richer than is needed, to avoid detonation. With the PowerFC you can simply dial in whatever AFR's you like and IGN timing to suit, anywhere on the map. This would certainly give a good power advantage in the midrange and top end.
How does the AVC-R compare to the PowerFC boost controller kit?
You can obtain the similar functionality from the AVC-R as you can from the PowerFC with the boost controller kit installed. The AVC-R and the PowerFC boost kit use the same solenoid and map sensor parts. It is confirmed that you can switch the AVCR solenoid and map sensor to the PowerFC boost kit but it should work. You can make the PowerFC display boost pressure without buying the Boost controller kit by buying the map sensor and using the Boost Kit Harness.
Parts list: What other optional parts are available for the PowerFC?
You will need:
Map Sensor
Map Sensor Harness
Solenoid
The main difference between the AVC-R and the PowerFC Boost Kit is the AVC-R can do gear judge or predictive gear based boost control and it has the pretty blue screen. The code logic, solenoid parts, wiring etc is the same.
Re: Apexy PowerFC
Сообщение MMX » 20 июн 2018, 21:07
How do I install the PowerFC?
Disconnect your cars battery and discharge all power from the car. You can do this by unplugging the battery and pressing the brake pedal a few times. Locate your cars computer and unplug the factory car wiring harness. The harness is usually screwed into the ECU so you need a Phillips head to undo the bolt in the middle. Once you have removed the factory-wiring loom you need to remove the ECU from its brackets. You can simply unscrew it and pull the ECU out. Once it has been removed put it in a safe place in case you need to go back to your factory computer. Put the PowerFC in its place and plug in the factory wiring loom the same way it came out of the stock computer. Be sure to note which way the ECU came out and match the pins/wiring notation correctly. Once it has been secured with the holding down brackets/screws you are now almost ready to start your. Before you start the car for the first time you should give the ACC key turn power so the hand controller turns on. If you are not using the PowerFC boost controller kit make sure you disable this feature. Go to the "Etc" menu and choose "Function Select" and then choose "Boost Control Kit" and set the option to a Japanese character that looks like a plus sign. This will disable the PowerFC boost controller kit. The PowerFC manual states to start the car, ensure no errors are present and let the car idle for at least 30 minutes. During this idle period wait about 10 minutes, turn on the air con, wait another 10, turn on the demister, wait another 10 minutes or so and then your car is ready to drive. If you short cut the self learn idle procedure once the car is turned off and back on again it will simply stall each time. If this occurs you must factory reset it again and do the procedure from the st.art
Disconnect Power
Unplug stock ECU
Plug in PowerFC ECU
Reconnect Power
Start Car, let it idle for approx 10 minutes before doing anything
Turn on aircon, let it readjust its idle and wait about 10 minutes
Turn on demister, let it readjust its idle and wait about 10 minutes
All done and you are ready to drive with your new ECU now. At this point you should familiarise yourself with using the hand controller and just checking the initial sensors and make sure the basic options are turned on and you know how to read the basic information.
Below is a list of things you should check before heading off to your tuner. These are just precautions and will make sure its ready to be tuned and avoid any silly problems at the start.
Installation Checklist:
Sensor Check
MAIN MENU, ETC, SENSOR SW / CHECK Look for any sensor names highlighted in BLACK background or any flashing sensors. Any highlighted in black indicates a problem. The engine check light will also stay on if any of the sensors aren't working (highlighted in black). This is not to be confused with the black DOT switch on / off sensors.
Stable Idle
The car should have a stable idle and shouldn't hunt. If it is hunting (revs bounce up and down a lot) and you can hear the engine "hunting" then you should consider a re-initialize and self idle learn again. If you don't have stable idle the car will be sucky and frustrating to drive.
Engine vitals OK
MAIN MENU, MONITOR, 8 CHANNEL,
Select the following
WtrTemp
Knock
BatVolt
Airflow
EngRev
InjDuty
Boost
IgnTmng
WtrTemp when the engine is warm and stable should be around 70 to 80deg.
Knock at idle should be 0 or like 1 or 2 at the most. Give the engine a few revs, ensure it returns to zero.
BatVolt should be around 14 at idle. Too low is bad and Too high is bad. over 15 is bad and under 14 can also be bad.
Airflow should be stable at idle, around 1100mv (millivolts). Should increase when you give the engine a rev and should return to around 1100 ater it returns to idle
EngRev should be similar to what the stock tacho says, it may be out a little bit. Ensure it follows stock guage when you give the engine a rev.
InjDuty should be around 1 to 2% at idle and should increase considreably when you give the engine a rev.
Boost (if not using the boost kit it will be ---) should be around -500mmhg at idle and should goto near 100mmhg with a free rev.
IngTmng at idle should be around 15 or 20deg. Should increase considerably with free rev.
No engine check list or exhaust temp light
The cars factory engine check light or exhaust temp light should NOT be on. If this is on or flashing it indicates a sensor problem. See the "Sensor Check" section on what to look for to identify the faulty or wrong sensor.
Restart the car a few times to ensure its stable
Restart the car a few times to ensure engine check light doesn't come on and idle is stable
Help! My car doesn't start once I've installed the PowerFC
Check that you've disabled the PowerFC boost controller kit in the step above. Check that you've chosen the right model PowerFC. Check that you've securely fastened the wiring loom and its not loose. Some cars only (for some strange reason) have half gauge wiring running from the battery to the ECU. This works fine for the factory computer but the PowerFC needs the full 12volts. You can simply run new 12volt wire from the battery to the ECU and this should correct this. This problem has been experienced by at least two members previously (both in R33 GTST) If the hand controller displays the Apexi logo and freezes then you have the wrong hand controller version or its damaged. If you find your car cranks, starts and stalls immediately you should check you have entered the correct injector and airflow meter settings (if they aren't standard items). If you still do not have a stable idle follow this procedure <
Turn car off
Turn car to ACC
On Hand Controller, ETC, DATA INIT, YES
Turn car off
Turn car to ACC
Change AIRFLOW and INJECTOR as needed (if different from stock)
Turn off Boost Control Kit (if not being used)
Start car and follow idle procedure
Failing that take the car to a mechanic/tuner who has worked on the PowerFC and see what they can sort out for you. It's pretty rare for a PowerFC to not start first shot - so double check the list, ensure you have done a DATA INIT on it and restarted the car etc before going further.
Once the PowerFC is installed can I expect any better performance or does it HAVE to be tuned?
It is always recommended that you get your PowerFC tuned for your cars mods. This will take into factor things like a lazy fuel pump etc that will be missed with just the factory tune. A full tune will ensure your A/Fs are safe and the engine is not excessively knocking and you are getting maximum benefit from the new ECU. A standard map will have benefit over the stock computer as it wont have built in limits the factory computer has and it also controls things like Variable Valve Timing better (on r33 RB25det at least) and provides more torque in the rev range without a tune.
Can I drive around without it being tuned for a few days? Months?
You can drive the car around as you would normally but you should take care not to put stress on the engine. Basically don't fang around in it, as you could be running unsafe A/Fs etc and just causing more damaged. Best to get it tuned. Make sure you watch the knock levels if you do this to make sure there isn't excess detonation.
Help! My car doesn't idle once I've installed the PowerFC
Your car should idle straight off the bat when it is installed on your car and you start it for the first time. Make sure you complete the idle procedure correctly and let it idle for 10 minutes in each stage. If you rush the idle self learn procedure you may end up with a car that doesn't idle. If this happens simply reset it. You should also check to make sure your AIRFLOW meter is selected correctly under SETTING, AIRFLOW (you can do this before you start the car).
Have a read of My idle is really crappy and it hunts around a lot when on idle. What can I do? for some more help on unstable idle etc.
Re: Apexy PowerFC
Сообщение MMX » 23 июн 2018, 09:15
Basic Hand Controller functions and use - Monitoring
Basic hand controller use is very simple and you can check and ensure your engine and system is running happily. Monitoring Values
Highlight "Monitor" on the menu and press NEXT and then select how much values you wish to view and then press NEXT.
You can now select which items you wish to monitor from the menu below
InjDuty - Injector Duty / How busy the injectors are
IgnTmng - Ignition Timing - Camshaft timing
AirFlow - Airflow meter voltage
PimVolt - Map Sensor voltage
Eng Rev - Engine revs
Speed - Road speed
Boost - Boost Pressure (requires optional boost kit fitted)
Knock - Knock sensor reading
WtrTemp - Water temperature or engine temperature
AirTemp - Air inlet temperature (sensor is not fitted on ECR33 skyline, DO NOT attempt to make this work)
BatVolt - Battery voltage
(Standard ECR33 Skyline menu options shown)
If you want to monitor your injectors and airflow meter select both of them after you choose 2 channel and then press next. You will then see them in their digital output mode on the hand controller. You can press UP to show their maximum values at any one time. You can press right to clear their maximum values. Any max values you see are cleared when you turn the cars power off.
The knock sensor when you view it by itself (1 channel) will give a bar graph like display showing knock. The Knock value is not number of knocks per second or knocks per engine turn, its just a number. The factory knock sensor is a microphone in the engine that listens for a certain frequency. When it detects this frequency it registers this as a knock, the higher the value the worse it most likely is.
Airtemp will always display --- on the ECR33 skyline as there is no air temperature sensor on the RB25. GTR / RB20 uses will have a value displayed which should show the air intake temperature. On the RB26 this sensor is located next to the throttle body inlet.
when viewing values via MONITOR you can also press NEXT and it will alternate between digital display and graph mode. When in graph mode you can use the "replay" function by pressing up and then PREV / NEXT
Basic Hand Controller functions and use - Checking Functions
Checking Functions
Highlight "ETC" and then choose "FUNCTION SELECT".
BOOST CNTL KIT - Enable/Disable optional boost controller kit
AIRFLOW WARN - Enable/Disable airflow warning
INJECTOR WARN - Enable/Disable injector warning
KNOCK WARNING - Enable/Disable Knock warning
02 F/B CONTROL - Enable/Disable 02 feedback
If the boost control kit is turned ON and you are not using it (not plugged in) the car will not start.
If the AIRFLOW WARN is set to ON the engine light will flash when the airflow value gets near its ceiling limit of 5 volts.
If the INJECTOR WARN is set to ON the engine light will flash when the injector duty values gets to 98%
If the KNOCK wARNING is set to ON the engine light will flash when the knock level exceeds 60
If the 02 F/B is set to ON the engine will utilise the factory oxygen sensors to save fuel
If you see your engine light flash whilst driving then goto MONITOR, 4 channel and then select
AIRFLOW
INJDUTY
KNOCK
IGNTMNG
Then repeat the same process and then press UP on the hand controller once you see the engine flash to check the max levels of each sensor you are monitoring. You can then work out which is causing the engine light to flash. On a stock ECR33 with the basic mods fitted youll find that you are maxing out all the factory sensors so in that case I turned my AIRFLOW and INJECTOR warnings to OFF and leave the knock sensor warning to ON. So if you see the engine light flash its a kNOCK warning and should be taken as a true "warning". You should speak to your tuner if you see high knock levels and the engine light flashing. A knock level of 60 is considered quite high.
If you have 0/2 Feedback turned off the PowerFC will not enter its closed loop feedback mode and will waste fuel and be very un-economical. Expect bad fuel economy
Basic Hand Controller functions and use - Checking Sensors
Checking Sensors
Highlight "ETC" and then choose "SENSOR/SW CHECK"
If you goto ETC and then choose SENSOR CHECK/SW you will see a list of sensors and corresponding values. These report values that the current sensors are returning. This can be useful for checking faulty sensors and to check if a certain sensor is working expectedly. Below is a translated list of the ECR33 PowerFC
Are there any hidden/secret features? Stuff you can't access by the Hand Controller?
If you have the PowerFC cable and software or the datalogit kit you can get to a few features that arent supported on the hand controller.
You can download maps to your PC and save them.
You can set the fan temperature turn-on value to below lower then 60deg.
You can set the millisecond values for the engine flash light for AFM, INJ, KNK levels.
You can access and control the air temp correction table.
You can adjust load map points by extended the airflow measure levels.
The follow tables/settings are also changeable
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
The following functions can be supported by additional hardware with Datalogit
Antilag via injection
Antilag via ignition
Intercooler spray
A/C and non A/C overheat fan temp switch.
Every standard sensor is logged
Optional logging for (lambda, brake temperature, suspension travel etc)
The PowerFC has a map for inlet air temperature which is not accessible by the Hand Controller but the table is still used by the PowerFC if it picks up Air Temp from the factory sensor. The Skyline RB26 has this sensor and the stock GTST loom can be adapted to support this sensor and allow the GTST PowerFC to read the value.
Does the PowerFC have any laptop hook up options or software?
The PowerFC has an official laptop software hookup but it is only for Power Excel workshops. These are workshops endorsed by Apexi and they will not give out the software. You can now purchase the official PowerFC Cable and Software for around $550 AU. This includes the official cable and PowerFC software. The Software is in japanese and so is the manual. There is an unofficial product called the FC-Datalogit. This is a 3rd party product that includes a dongle/serial cable and software. It's retail is around $520 AU and supports full control of the system just like with the hand controller and supports logging to your laptop for replaying and viewing later. You can also make your own cable/dongle providing you know how (and have the PIC processor code). The diagram on my site needs PIC processor code to work and this code is NOT avaiable, is it not released for public use, please do not ask for it. Should cost around $50 in parts, then you can use the PowerFC Pro (if th cable works) software from my site. There is a new product on the way due for release in August which is the FC Tune. This appears to have the same functionality as the datalogit however it supports all of the cable types including a custom made one. Retail is rumored to be around $299 USD for the cable. The software is free.
Apex'i FC Pro Software and Cable (retail product)
FC Tune and Cable
Datalogit FC Edit and Datalogit Connector Box (retail product)
Kashima's custom cable (needs PIC processor code)
You should read here if you are intersted in
Re: Apexy PowerFC
Сообщение MMX » 30 июл 2018, 08:47
What does the PowerFC support in terms of modifications?
The PowerFC can support bigger injectors, larger turbos, aftermarket plenums, superchargers, nos kits, etc. The PowerFC is able to do this by allowing the tuner to adjust all the parameters of the engine on a load vs. rpm map for each of the core components. You can tune the computer to run xyz amount of fuel at 2300rpm on load xyz and to have xyz timing at the same load etc so the combinations are virtually endless. It will also support bigger airflow meters, different and custom meters, larger fuel pumps etc.
What do I need to do when changing my Airflow Meter?
When you choose another airflow meter to allow a large opening diameter or a higher resolution meter you need to select the unit from the [SETTING], [Airflow] menu and select it from the list. You should do this before you start your engine to prevent really unsafe mixtures and also to prevent stalling/bad idle. Once you have highlighted the correct model you have fitted to the car you can simply press [PREV] on the hand controller and return to normal [MONITOR] and start the car. It should idle OK (well hopefully) however this does not mean it is safe and ready to go. Selecting the correct airflow model simply loads the voltage ramp table into the PowerFC. This tells the PowerFC at what airflow levels the meter is reporing in its voltage range. You should have your AFR's checked with your tuner and a wideband after an airflow meter change to ensure its not too lean or too rich. If you need to drive a fair distance to your tuner or would like to run around for a few days on the new airflow meter without it being retuned/checked then theres a simple procedure you can follow
1. Let engine warm up and idle
2. Give the engine a bit of a rev in neutral and check to see if smoke comes out the exhaust.
3a. If you see *some* black smoke
-> Then its running rich (preferred) and it should be OK to drive around on light/low load, although your fuel economy will probably be terrible.
3b. If you see *lots* of black smoke
-> Then its running very very rich and you'll need to lean it out a bit. You can do this by going into [SETTING], [IGN/INJ] and then on the right hand side you will see INJ correction. You can then slowly change the ADJ value to a negative value in small increments. After a few adjustments give the engine a rev and there should not be as much black smoke. Repeat until there is a little bit but its not *lots* of black smoke.
3c. If you don't see any black smoke
-> Then its running lean or possibly too lean. Do the same procedure (as above) but add more fuel by adding or upping the ADJ value and after a few increments try a free rev. If you get some black smoke then you are starting to richen it up.
4. You should remember this value or write down the correction number used because if you turn the car's power off you must come back to here each time to put the value back in. This is because its only a temporary test mode and it should not be used all the time. You could also give this value to your tuner to give him an idea of how rich its running.
Source: Apexi Documentation
80m RB25 airflow meter can measure up to approx. 300ps (221kW)
80mm VG30 airflow meter can measure up to approx. 500ps (368kW)
90mm VH41 airflow meter can measure up to approx. 400ps (294kW)
*Output is calculated off of measurable air volume
Airflow Meter Adjustment Range
Using 100% as a base, the airflow can be adjusted from +50% (-50%) - 200%
How do I configure larger injectors?
Configuring larger injectors into the PowerFC is quiet simple and takes only a few moments. You need to know the following information before you can continue
Current injector size
Current injector latency
New injector Size
New injector Lag time
Injector Size and Latency (standard units)
To work out new INJECTOR correction and latency;
Old SIZE / New Size = Correction
New Latency - Old Latency = Latency Correction
John plans to install 600cc injectors into his RB26 VL Turbo. The following figure's are used;
444 / 600 = 0.74 * 100 = 74.0%
0.81 - 0.77 = +0.04 msec
So he would enter 74% for correction and 0.04 as new latency
Once you have switched to larger injectors you should still check your AFR's with a wideband to ensure they are safe and acceptable.
For a list of common OEM injectors and their settings try here;
Injector Chart - Side Feed OEM
Injector Chart - Top Feed OEM
Unit Size Latency
RB20 260cc/min 0.890msec
RB25 370cc/min 0.528msec
RB26 444cc/min 0.772msec
SR20 (Jap Spec Manual) 448cc/min 0.584msec
Nismo 480cc 480cc/min 1.100msec
Rx7 550cc 550cc/min 0.730msec
Nismo 550cc 550cc/min 0.710msec
Aftermarket New Units (example only) 600cc/min 0.810msec
If changing 440[cc/min] to aftermarket 600[cc/min]
440 / 600 = 0.73
Enter the value "0.73" for each cylinder.
Bolt-on turbo spec. POWER FC applications assume that the injectors have been upgraded. This is why "1.000" is not entered as the starting data for the injector values.
Injector Lag Time Setting
The POWER FC includes factory vehicle injector data. If you switch to any other type of injector, be sure to perform the calculations below and input the correct values.
Changing the factory 440[cc/min] with 0.78[msec] injector lag time to an aftermarket 600[cc/min] injector with 0.85[msec] injector lag time is:
"Injectors to be used" - "Factory Injectors" = "Correction Value After Changing"
0.85[msec] - 0.78[msec] = 0.07[msec]
Enter "0.07" into the [msec] parameter for each cylinder.
*If the aftermarket injectors have a shorter lag time, add a "-" (minus) before the value.
Изображение Изображение Изображение
On this screen you need to enter your new Correction% and Latency. Be sure to double check these numbers and consult your tuner if you are unsure.
If you enter the wrong values, this could be fatal to your engine so be careful.
Re: Apexy PowerFC
Сообщение MMX » 22 авг 2018, 09:29
How do I setup a larger scale map sensor?
If you are maxing out the factory map sensor supplied in the Boost Control kit for your car you'll need to install a larger unit. These units are commonly used in the "wild" but feel free to find your own if you wish;
AEM 3.5bar sensor
GM 3bar sensor
APEX 3bar sensor
APEX 4bar sensor
Here is a list of what you need to upgrade your Map Sensor. This spreadsheet should help you determine the settings for Scale and Offset for any typical linear 5V MAP sensor.
The idea is that you measure your new MAP using:
a 12 Volt or 5 Volt source (for powering the MAP - I think most use 12V?)
a pressure/vacuum tester (like a MityVac or similar)
a multimeter (for reading output).
This speadsheet
You put the info you gather into this sheet and then play with Scale and Offset until it matches your experimental data. Don't bother downloading this unless you have all the items listed above in 1, 2, and 3.
This was taken from the Rx7 forums as they often have to upgrade their map sensor. Wargasm is the author of this content so be sure to check out his thread if you have questions or issues regarding this.
PowerFC Pro - Launch Control
The Launch Control in the Apexi PowerFC Pro version is very simple. It allows you to set an alterate RPM for 0km/h so this is your "launch" rpm.
Under the SETTING, REV LIMIT screen simply enter your desired launch rpm as the second option. This is your new launch control rpm limit. When the vehicles speed is 0km/h this will be the new rev limit.
Basically if you set the 0km/h launch RPM to say 3600rpm and your car is stationary (speed must be 0km/h).
If you floor it the revs will fly to 3600rpm and stay there (it should also spark cut - aka flames and bang bang). As long as the car isn't moving your RPM will halt at 3600rpm (or whatever you set) and stay there. Once you release the clutch the 0km/h limiter will deactivate and it will move to your normal RPM cut. So as you take off the car will launch etc and your RPM limiter will be say 8000rpm or whatever you set for the other RPM limit.
Re: Apexy PowerFC
Сообщение MMX » 28 авг 2018, 10:11
Advanced Operation - Optional Kits for the PowerFC
How do I hook up the optional Boost Controller kit?
The optional boost controller kit for the Power FC consists of the pressor sensor, pressure sensor harness and solenoid. The solenoid should be plumbed between your manifold and the wastegate actuator (internal wastegate setup). For external wastegate setup it should be plumbed between the manifold and your external wastegate pressure line. The pressure sensor should be plumbed in parrallel with the factory MAP sensor which is used by your standar boost guage.
The solenoid has two labels on it, you should match them accordingly
COM line should goto wastegate actuator
NO line should goto intercooler piping
It can be T'eed into the plumbing with its included T piece fitting.
Boost Controller Kit Type #1
3 wire plug, Solenoid runs to stock boost control loom on stock ECU wiring loom.
3 wires in Apexi loom are for Map sensor - Signal, Ground and Power
Boost Controller Kit Type #2
5 wire plug, Solenoid runs to map sensor harness which runs to Boost Controller port on PowerFC
3 wires are for Map sensor - Signal, Ground and Power. 2 Wires are for Solenoid Power and Ground
Skyline RB25DET PowerFC and GTR RB26 Uses Type #1
The pressure sensor has the main wiring harness directly attached to itself, one end plugs into the 5 pin port on the PowerFC. The solenoid piggybacks off the Pressure Sensor wiring harness which leads to the PowerFC connector port. The wiring is shown below.
MAP Sensor
Red = Positive
Black = Negative (earth)
Green = Signal
Solenoid
Pink = Positive
Black = Negative
When the solenoid wiring meets with the Map Sensor harness the colours for the Soneoid change as follows;
Pink = Red
Black = Brown
Boost Control Kit - Parts Inventory
Boost Control Kit - Complete Kit
Boost Control Kit - MAP Sensor
Boost Control Kit - Solenoid
How do I configure the Optional Boost Controller Kit?
Once the harness and sensors have been connected you need to turn the Boost Controller Kit on under ETC, FUNCTION SELECT. You need to set the Boost Kit option to ON. The OFF Symbol looks like a plus sign in Japanese so be sure its opposite to this. All that is left is to the set the disired boost pressure, SETTING and then BOOST. On this screen you will be presented with 4 options.
Each option is a preset boost pressure and duty item, the currently selected one is the active "boost profile".
The first value is Boost Profile Number.
The second value is the maxmium amount of boost you wish to run.
The third value is duty cycle
The fourth value is unused (always 255).
Boost Pressure
1. 1.00 kg/cm2 40 255
2. 1.10 kg/cm2 46 255
3. 1.20 kg/cm2 52 255
4. 1.30 kg/cm2 60 255
Choose boost profile #1
Set target boost pressure
Do a test 3rd gear drive and see what boost it reaches
Adjust duty cycle as needed
Lower number if boost is too high over target boost or if safety cut is reached.
Increase number if boost is too low or it doesn't reach desired level.
If the map sensors detects that boost pressure is 0.25kg/cm2 over the set boost pressure then it will do a safety cut to protect itself. If you find the car is unable to make the pressure you desire, increase the duty cycle value. If you find it makes it to easily or it's having trouble maintaing a stable pressure or keeps hitting the cut limit then turn the duty value down. You can also set the other 3 boost profiles here if you wish so that you can select these later on allowing you to quickly change preset boost on the fly. The current selected profile (option 1,2,3 or 4) is active when you it's highlighted and you press PREV to navigate to the other menu's.
Basic Duty Setting
Our boost control uses duty-cycle of the solenoid valve to control boost pressure. The setting of this duty-cycle decides the basis of the control to match actual boost with desired boost level.
The numerical value should be increased when the boost level does not reach the above-mentioned setting. The numerical value is decreased when the boost level surpasses the above-mentioned setting (desired boost level).
A rule of thumb is that it changes by the boost value by 0.1 (about 9.8kPa) when duty cycle changes approximately 6%.
For example, when current duty is 56% and boost setting is 1.1[] (approx. 107.9[kPa]) but the boost raises only up to 1.0[] (approx.98.1[kPa]) , in order to raise 0.1[] (approx. 9.8[kPa]), you have to change the duty from "56%" to "62%".
Some mechanical conditions may prohibit boost from reaching the target boost.
Please set it to the correct duty value that corresponds to the boost setting value.
Please note that it causes the overshoot or hunting of boost pressure and self learning control if the boost selection and duty-cycle does not match.
How do I hook up the D-Jetro Map Sensor Harness Kit?
There are various installation methods for the Djetro Map Sensor depending on the Car Model.
This will depend on your car - it's recommended to view the documentation for your specific Djetro model.
The manual will be in Japanese but the wiring should be in clear english with pinouts etc.
Evo Lancer CT9A do not have to do anything as the car runs a factory Map Sensor
Skyline RB26 customers must splice twin Map sensor into the Airflow meter signal wires on the std ECU loom
Nissan S15 customers must also manually splice a single Map Sensor into the harness (via AFM signal wire)
Below are instructions on how Skyline RB26 customers should connect up the Djetro kit.
It appears that D-jetro customers must splice the twin map sensors into the Boost Control Kit harness (or at least use the same port) to extract positive and negative power.
The signal for each MAP sensor is then connected to each of the AFM input signals on the main ECU loom.
So Map sensor #1 which is located near Cylinder #3 on the intake plenum runs to AFM input #1 on the ECU loom.
and Map sensor #2 which is located near Cylnder #4 on the intake plenum runs to AFM input #2 on the ECU loom.
For a more in depth diagram and guide please view the correct manual for your car's Djetro version as it will have correct Map Sensor wiring.
Replacement or upgradable Map Sensors for the Boost Control Kit / Djetro Kit?
The Djetro and Boost Control Kits use standard mainstream map sensors to provide manifold pressure in digital output. You can use most OEM map sensors to give you a larger scale and accurately show more pressure to the ECU. Here is a short list of known working replacement map sensors;
AEM 3.5bar sensor
GM 3bar sensor
APEX 3bar sensor
APEX 4bar sensor
Re: Apexy PowerFC
Сообщение MMX » 21 сен 2018, 09:47
Tuning Information
Can I tune the car myself?
You sure can if you know. You can also look up some DIY threads using a lambda sensor and the trial and error procedure. Be warned you are playing with an electronic controlling mechanism of your engine and any incorrect setting could cause bad things. See the below parts on the Map Tracer for some info on Self Tuning. You can self tune the ignition timing yourself with trial and test method but you should not do this for fuel injection as you can lean it out too far and burn the exhaust valves which is permenant engine damage. Self ignition timing tuning can be done quite easily and will certainly aid in more fuel economy. It's not recommend for more power as this should done on a dyno so you can ramp up the load and max out to 200km/h without breaking any road laws / putting yourself at risk.
What is Map Tracer? Is it useful?
Map Tracer can used to work out what map the powerfc is currently using. Each map contains settings that powerfc should apply to the engine. A map is a 20x20 grid each position has a value. There are maps for fuel injection and ignition timing.
The map has 20 load points and 20 rpm points. Each rpm point is 400 rpm. This grid looks like:
A map for the ignition timing values looks like this (rb25det map)
A completed map trace in 2nd gear going from idle to redline looks like this. Please note this is done with full throttle, aka the pedal is to the floor:
Load is based on how much airflow the airflow meter is measuring. Going up a hill in 3rd gear at 50km/h may be represented as load value 13 if the airflow meter is seeing 4.1volts of "air" and an rpm point of 11 if you were at say 4400rpm. The load value (vertical left side) 13 out of 20 represents the amount of engine load being placed on it, which is taken from the airflow meter measurements. The ECU also knows how hard you've pushed the pedal based on the "THRO" sensor. So the powerfc uses these "values" that it's given in real time to work out what cell values to use for ignition timing and fuel injection. This forms the basis for tuning the engine as you can adjust any load point you like how you see fit. It's a little clear when you see the below diagram: If you were noticing an issue when under a certain load or rpm you could run a map tracer see what map cell is being read and then adjust the corresponding map value under ignition or fuel. To have the map tracer save the map its accessed on the map tracer screen press next when in map tracer and as it goes through the maps it will leave them on the screen. Just like if turned on mouse trails in windows, you see the previous trail it has left. This makes it easier to debug what the ECU is doing and what values need to be adjusted to alter how the car runs based on the map values being read in at real time.
Below is a map trace of light and medium throttle. This was done from my car based on a 15 minute drive around my local streets on what I would consider normal throttle. The majority of the time you aren't on full wide open throttle. Most tunes are done based on the car being on a dyno with the throttle wide open to check for safe A/F and tune for max power. This is fine however you will lack fuel economy as the a/f's for low and medium throttle are no where near the full open throttle a'f/s.
As you can see from this most of my time or "operation" is spent on the top left of the Map. Now remembering that load is up and down and rpm is left and right. So based off this trace we can see I'm not hitting much load, the most is about point 10 and rpm the most I'm hitting is point 8. So the max for that trace is load point 10 which is about 2/3 of the airflow meter max on the r33 gtst (The stock powerfc and afm can only show upto 15 points for 'load' reference). The rpm is 8 * 400 = 3200rpm. So I didn't go over 3200rpm and didn't give it lots of throttle but enough to access the lower end region. So going from this my fuel economy is fairly good but I am sure I can get better so we need to drill down to the fuel cell values for those highlighted maps as I am sure they weren't tuned on the dyno as this wasn't a priority for the initial tune. More to come on this topic as I further look into my tune and try and get some better fuel economy. Consider how much time you spend on full throttle vs low or half throttle and you'll realise where your fuel economy has gone. Out the window as the majority of the fuel cells you are reading are highlighted above and they are default apexi map values so they need to be tweaked.
My fuel economy is terrible and I just had a complete tune, Whats wrong?
A "complete tune" is not always a complete tune. It is most likely just a high power run, that is run the car on the dyno and suck out the most power you can and make sure it doesn't knock. Usually advance the timing, lean it out and make sure its a safe tune. This is done on full throttle usually in fourth gear (as stock diff ratio is 4:11) which is the closest to 1:1. Now think to your driving habits, how often are you on full throttle for the entire duration of your tank of petrol? 5% of the time seems reasonable but your entire tune is based on full throttle and max load, certainly not your ideal tune as far as economy. You should read up on how to use the Map Tracer here before continuing any further as you need to use this as part of the tuning process.
Speak to the tuner if you still have terrible economy. Ask to have the light cruise AFR's check on the dyno with a wideband sensor or even better as them to come for a drive with you wide a wideband sensor up the exhaust. Show the tuner your typical driving habits and make sure the AFR's are nice and lean on light cruise. My car is setup to be around 16 AFR's on light cruise which is safe & reasonable providing it is done correctly. Below is a simple checklist for poor fuel economy;
Check the tune (light cruise AFRs etc)
Make sure closed loop 02 feedback is on (ETC, FUNCTION SELECT, 02 FEEDBACK)
Make sure you have a working 02 sensor (ETC, SENSOR SW CHECK, 02-1 (for gtst) should howver between 0 and 1v)
Don't constantly load the car up to get it on boost over and over
Keep a steady throttle (02 feedback doesn't work if you keep moving the accel pedal, keep it constant in light cruise)
Self Tuning - Ignition Timing
Things you will need:
1 x Friend
1 x PowerFC Hand Controller
1 x Road
This should be done on quiet road with someone else driving your car. This should not be done by yourself, in peak hour, in lots of traffic or anywhere that seems obviously dangerous. Your own private road is probably the most suitable, and we all have these of course. Ok drive around normal load, cruise around 2200rpm ish. Watch the knock value under Monitor (1 Channel). It shouldn't knock excessivly, be sure to press UP so you get a "digital" value as well as the barchart on the hand controller. Knock is a signal picked up by a microphone inside the engine itself. It is not 100% accurate and it can pick up other things that are not "engine knock" but merely things that sound the same. Knock over 60 is bad and will flash the engine warning light, by default. Whilst on low load, light cruise goto Map Tracer and see what values are being read. It should be somewhere around say rpm point 7 (2200rpm) and load point 3 or 4. Just watch it vary around as your driver varies the load (varying accelerator pedal pressure). This is because as soon as the driver varies the throttle the engine loads up and takes in more air. The airflow meter see's this and increases its measured "voltage", which in turn adjusts what cell the PowerFC is using. Ok now goto Setting, IGN/IJN and on the left side you will see IGN Corr. By default it will be 0. Increase this value to +2 and then go back to Monitor, 1 Channel KNOCK and see if the knock goes up a little bit. A little increase in KNOCK is OK and acceptable, values jumping all over the place or constantly hitting 40/50 odd all the time is bad. You can clear the max "digital" knock value by pressing right when it is displayed along with the barchart. If the knock appears to be minimal then get your drive to vary the throttle a little. Try slowing applying more pressure to the accelerator pedeal in 5th gear at say 50km/h. This should throw the map trace down the left axis as the load increases. See if the knock goes up and down much as it's. Don't worry about full load, flooring it as we aren't interested in that. In fact this is not recommended as running advanced timing under heavy load can make stuff go bang. Try going into lower gears such as second and doing very slow takesoffs and very small amounts of load. Keep checking the knock values and make sure it is OK.
At this point you shifted the entire ingition timiing map up 2 degress everywhere. The car should be a little snappier and sharper under accerelation (This is good). As long as there is very little knock or hardly you should proceed to save this adjustment and monitor your fuel economy. It is recommended to do minor adjusments one step at a time to see the effects and also to prevent a big change instantly. +2deg timing increase should give a good increase in fuel economy. See if you can set IGN CORR to +4 and watch how much knock you get, if its minimal then its time to permenantly set the new tune. Again make sure its safe and not knocking before you do this. If you do this incorrectly you may have to either revert every value back or reset to defaults and loose your tune (You've been warned). Set the IGN CORR back to 0 deg and then let your driver have a rest or turn the car off but keep ACC on so you can keep using the hand controller. Have a rest and a drink as your eyes and head will hurt if you suffer motion sickness as watching map trace and knock while someone drives around really sucks. Ok now we wish to move the "light/medium" cells up 4degress. We don't want to move the whole map up as we've already had a max power tune which is fine we just want more economy. See below picture of what I feel are the light load / medium load cells which are used the majority of the time. These are the cells we want to "tune", aka thrown in our +2 deg correction permenantly.
For each of those cells highlighted, or even ones you wish (only recommended to do the first 8x8 as an abosolute maximum at this stage) do the following procedure.
1 Setting
2 IGN Map
3 Nagivate to cell you wish to alter, you can see the rpm points across the top, and load points down the left.
4 Press NEXT to enter the adjust cell screen which will show what RPM point and LD (load) point you are editing
5 Press NEXT to edit the value and then you can press UP to increas the value, in this case do it 2 times. The value will go from say 20 to 22.
6 Press NEXT to save the value change
As you can see by the above procedure it takes a bit of time to edit all the cells, the quick method is start at 1,1 and then press NEXT,NEXT,UP,UP,NEXT,RIGHT and repeat until you reach RPM point 8 or 9 and repeat for each load point upto around 8 or 9.
What are the percentages for my airflow voltages for?
The airflow meter percentage or "correction" per AFM voltage braket is simply that, a correction for each voltage range. This allows the tuner or operator to show more or less Airflow to the Load map, which in turns moves it final load bearing on the load map.
At 80% for the say 3.20v braket means that any airflow between 3.20v and 3.84v (standard GTST scaling) will only show 80% to the laod map. So if by default it was to land on load points 10 through to 13 then it would end up landing on load points 8 to 9 instead, 80% of the airflow load. You won't have less or more power as the same amount of airflow comes into the system, it just affects how it is represented on the load maps.
This allows the tuner to move the load bearing around on the map quickly and easily to effectively shift the map up and down. The benefit of doing this is you can quickly shift the load bearing around without adjusting 60 odd load points on the load map, for IGN and INJ settings for a given AFM voltage bracket. This is one of the more common methods for quick tuning of the PowerFC but certainly not the only one. This is more common with standard to mild setups, which can include Cams, Turbo's, AFM's etc. There does come a point and time where it is quicker to just leave the voltage correction all at 100% and move on the maps directly and begin altering the INJ and IGN values directly.
Is there a way or guesstimation to calculate AFR's based on the INJ values?
You can use the following calculation as a guesstimation for target AFR's
Target AFR = 14.7 / INJ value
This is by no means a true relationship to the AFR's that come out in the end. It is exactly that, a guesstimation or rule of thumb. You should always use a fast and wide lambda or 02 sensor to determine the true AFR's The most recent version of datalogit lets you view the INJ table in Lambda, INJ values and AFR ratio using this method.
I always have knocking, is it true, is it lies or is something wrong?
The factory knock sensors are exactly that, small microphones attached to the outter casing of the block and they listen for certain frequencies. The frequencies they detect are those heard when detonation occurs. Hence the name, knock sensors. To sense engine knocking/detonation. Is it possible for knock sensors to detect other noises and vibrations from the engine (and road/environment) but they usually do indicate a problem.
The knocking level found in the Apexi PowerFC refers to the level of knock detected not the frequency. Higher voltage indiciates a bigger knock has been heard or detected and it is displayed on the hand controller.
You cannot alter the sensitivity of the knock sensors. You can alter the flash sequence or how often it should flash when a certain knock level is reached (using Datalogit).
A knock or 50 when the engine is on small amount of load at 3300rpm is much different to a knock of 50 when the engine is on full load at 5800rpm. The higher the load and RPM the harder the engine is working, the more likely detonation is going to occur, and the severity of it also increases. Knocking in low rpm can often be overlooked or just accept the fact and move on with things, but knocking under full load near mid to high RPM is a concern and always should be.
Do NOT ignore detonation - it can be an engine killer if ignored and the driver acts like a stupidhead - always check and find the cause or speak to your tuner. If the engine light is flashing its for a reason - get it sorted or be prepaid for heavy rebuild costs etc. It is better to be over-reactive when dealing with knocking than to ignore it and play the dumb driver "i didn't know"
How do I debug knocking, how can I make it go away?
There are 5 methods that come to mind immediately when dealing with knocking and their apporaches are listed below. Before you go ahead and try to be a cowboy fixing knocking if you aren't comfortable etc or don't know what you are doing go and see your tuner. Tell them all the information you have and get it sorted - Don't ignore it or just hope for the best. Either fix it yourself or speak to your tuner.
1. Use temporary IGN adjust
Drive around and replicate the concering knock levels, be sure to note roughly where it happens (rpm or load etc).
SETTING -> INJ/IGN Adjust -> Press DOWN 3 times and you will see -3 for IGN ADJUST. This drops the IGN map 3 degrees timing temporary (will reset when car is powered off).
Drive around and try to replicate the knocking levels again, be sure to try and reproduce the engine load and rpm you did previously. If the knocking has dropped considerably or has gone away completely (very likely) then it is simply a few cells on the IGN map have too much advanced timing.
You should give this information to your tuner;
Max Knock of: 50
At RPM: 4700
At Engine Load: Max Load (throttle was nailed)
Using Fuel: Standard BP Premium
Adjustments: -3 deg IGN timing fixed the problem
The tuner then has enough information to drop onto the IGN map and take out 3 deg timing where 4700 and max load lands on the IGN map. Should take no more than 5 minutes to correct and all be happy. The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one.
2. Use higher octane fuel
Find a local service station with really high octain rated fuel, Shell V Power Racing is a good one. Plonk in a full tank of V Power Racing in and drive around for about 5 minutes to get the fuel flowing.
Drive around and try to replicate the knocking levels again, be sure to try and reproduce the engine load and rpm you did previously. If the knocking has dropped considerably or has gone away completely (very likely) then it is simply a few cells are possibly too lean on the INJ map (could also be IGN timing). Running a much higher octane rated fuel is almost guaranteed to take away some detonation. I am using Shell V Power Racing (100ron) and its fantastic as a detonation killer (highly recommended).
3. Adjust IGN map
Max Knock of: (highest level you saw)
At RPM: (what RPM you noticed the engine check light come on)
At Engine Load: (driving conditions)
Using Fuel: (what fuel you used)
The tuner then has enough information to drop onto the IGN map and take out 2 degrees timing where your driving conditions land you on the IGN load map. Should take no more than 5 minutes to correct and all be happy. The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one.
4. Blanket approach
The blanket and braindead approach is to drop the whole map 3 deg either using Datalogit or dialing the crank angle sensor backwards a notch, this is NOT recommended as its braindead. You have stand alone engine management, it should be used like one. Lowering IGN timing is likely to take away any detonation but will certainly give the engine a flat and empty feeling (not recommended).
5. Ground Zero approach
Set the IGN timing from 4500rpm to 6000rpm at zero degrees.
Set the INJ map from the same load areas to 10.5 to 1 (mega rich).
That should complete eliminate any knocking, that is it is not humanly possible for it to knock now. Do a max load dyno run (damn it will be boggy and make jack all power) and see what knock levels you get now. If you still see knocking then its likely the sensors are picking up other mechanical noises in the engine bay. Using a chassis ear tool would assist in debugging where the noise is coming from.
One owner reports;
"Then I went for a little walk around the engine bay on the dyno with the chassis ear. It turned out to be the remote oil filter sandwich plate tapping on the oil pressure gauge adaptor. They were located right under the rear knock sensor. There was obviously was a slight engine vibration at that RPM, which I later traced to an unbalanced pressure plate."
So it certainly is possible for other external factors to cause "knocking" and thats the Ground Zero, rule out everything else approach.
Re: Apexy PowerFC
Сообщение MMX » 01 окт 2018, 08:12
Technical Issues
Why does my engine light flash when I drive with the PowerFC?
The PowerFC uses the factory engine warning light to alert the user of "upper limit" or ceiling values in the engine systems. Things such as airflow meter max value, injector max duty, excessive knock will cause the engine warning to flash. Usually the engine flash is in a sequence of 3 flashes each 0.5 seconds apart. Should you experience this you should review the hand controller max values (press down when in monitor mode and displaying values to see the max values for each) and consult your tuner immediately. Excessively high knock can cause engine damage. Running on max injector duty can also be fatal so speak to your tuner. Aggressive tunes that are tuned around winter temps/airflow and being run hard in summer may cause these symptoms if the tune is very aggressive and on border line of maxing out the stock components. This is only hearsay but I have seen this from at least one or two members.
See Basic Hand Controller functions and use for information on how to isolate which warning is triggering the engine flash light
The first step when installing the PowerFC is to let it idle for upto 30 minutes on your car so it adjusts to your engine setup. This includes turning on the Aircon, Demister and Heater throughout the idle stages so the ECU has time to learn the engine setup and idle levels. This can be done by doing an "initialize" on the PowerFC. This will reset all settings back to default (including your tune) and set the PowerFC back to learn mode (for idle only). You should not do this if you have a tune as there is no way to save the tune before it is erased. If you have datalogit or the FC Pro cable/software you can copy the maps. Preform the initialize and then reupload the maps. A few people have seen really screwey idle from the Hand Controller itself being plugged in. The workaround is to unplug the Hand Controller and it idle's normally. This is a very strange problem and certinaly not common. Initial suggestions would lead to an electrical problem somewhere? If you still stuck with a unstable idle, try the factory ECU and does the idle bug go away? If it is still present it could indicate a mechanical issue with the factory idle control (usually the AAC valve). You can reset the PowerFC to factory defaults to "re-learn" the idle control from scratch and this seems to fix most idle related issues, such as hunting at idle and also high RPM surge when coming off a gearchange or throttle acceleration.
Last but not least if you still have screwy idle speak to an auto elec or mechanic. There could be something else wrong that requires further attention.
I am seeing on my Map Tracer that I am reaching load point 19-20 on full throttle. I am maxing out the PowerFC! What can I do?
Load or what is considered "load axis" on the powerfc maps is based on values fed from the airflow meter. If the airflow measure "lots" or air the powerfc moves down the axis on the left and reads the corresponding values. What happens when your AFM is showing the ceiling or "highest" values the powerfc has calibration for then you are stuck with a "flatline" load map which would look something like:
From here you can see it drops the max load points fairly quickly. This would most likely result in being unable to accurately tune from 4000rpm onwards as it just keeps reading the same load values each time (aka end of the map). This issue has only been found to occur with the AP Engineering RB20 PowerFC and using a "high load" setup such as an RB30 bottom end conversion. The issue is correctable by "extending" or "stretching" out the airflow meter reference points. This corrects it by when the airflow meter measures 3.2volts the powerfc matches that to load point 11 as an example. By default the AP Engineer PowerFC looks to reference the max load points a little early with an ugprade intake system and maxes out a little to early. This is not to be confused with the actual airflow meter maxing out at 5 volts. The correction in this case is to obtain the RB25 airflow map refence points and use them instead of the RB20 ones. This then "extends" the airflow meter range and allows it to run around the load point 15 mark on full throttle instead of the bottom of the map. This should allow for more accurate tuning as there is room for "increased" load because there are 5 or 6 "points" to advance in load before its at max again. This cannot be done with the Hand Controller as it requires the FC Pro software, Datalogit or Fc Tune to access the airflow ramp tables.
Any changes made to settings on the Apexi PowerFC are written in memory and then commited to NVRAM when the car is powered off. When the PowerFC detects power loss to IGN it saves its state into NVRAM. This usually takes around 1 second. Once this is complete the unit is safe to be powered off (happens automatically). If your car has had an engine swap it is possible and likely that the standard ECCS wiring has been altered or is not the same as factory. This may mean that when the IGN is turned off the PowerFC doesn't have time to save its changes. This results in any changes made to be 'lost' when the power is off. Below is a diagram on how it should be wired in with the ECCS relay. The diagram is suited for the RB26 ECU so if you have a different version look up your corresponding ECU's diagram for the matching wires.
When I turn my car on I get a clicking relay noise and the hand controller dies
This is related to an ECCS / Power source wiring problem. Either the PowerFC does not have the right voltage, a chip/circuit is damaged in the PowerFC or the unit is possibly faulty. When I fried my PFC due to a misconfigured wiring loom I had this problem. I opened up the PFC and found a burnt track. I resoldered the burnt track and all was well. I encounter loud clicking noises from the PFC, and garbled text and characters on the hand controller when the IGN had power. You can view a similar topic here When I turn my car off I loose any changes on the PowerFC! Help!!
My car won't start when I plug in the PowerFC, but the stock ecu works fine
First when dealing with a new PowerFC install and the car does not start there are a few basics to check;
Check the PowerFC to car loom connector
Check the warning lights on the dash, do they come up?
On the hand controller, goto ETC, SENSOR SW CHECK, are any sensors highlighted in black? (Shouldn't be)
Make sure you disable the Boost Control Kit if you aren't using it
Make sure you have the right airflow meter selected (if you have a non standard one)
Make sure you have correct injector settings (if you have non standard ones)
Check all fuses
Listen for clicking relays
Check for burning smells near the ECU and or inside the ECU
Inspect the ECU itself for physical damage or burn marks (open it up)
Finally we have seen on a few skylines that the car works fine with the stock ecu but not the with PowerFC. It has been traced back to a missing fuse. The missing fuse is on the left side in the R33 GTST and its at position #7. According to the diagram it is Engine Control. Somehow the stock ecu works if this fuse is missing but the PowerFC doesn't
See the diagram here for "Engine Control" which is a 10AMP fuse.
My Skyline R32 GTR has a wierd misfire problem, what's wrong?
This topic is currently under discussion and there is possibly a pattern among R32 GTR owners. The PowerFC used is the same version as the R33 GTR PowerFC but this bug/problem only appears on R32 Skyline's. An intermittent misfire problem when coming on full load seems to be the common factor.
8.04a and 8.0 are known versions to be affected by this bug.
I installed a new engine cover (the bit in the middle that covers the coil packs) - this allowed me to move the ignitor pack back up on top of the engine cover. I took that opportunity to make sure I had a good earth when I moved it (which I assume the guys from Mercury have not) Prior to having the engine cover on - the coils and the ignitor pack shared the same earth - and I was just using one of the screw holes that holds the coil pack (plug) leads in place I plan to make a dedicated earth strap over to the -ve battery terminal over the weekend
The user reports that "New earth for the ignitor pack fixes it"
Thanks Scott
For an ongoing discussion you view it here This is a confirmed unofficial bug in the RB26 R32/R33 GTR LJetro PowerFC. This has been seen by quiet a few users with reproducable results. You should read the Skylines Australia thread above for known workarounds and fixes etc.
I have fried my PowerFC. Is it fixable?
We have seen on a few occasions that an Apexi PowerFC is in fact fixable and can be repaired. The usual suspects are burnt tracks, fried chips or damaged circuits on the board itself. One member was able to send their PowerFC to a local electronics shop with a wiring diagram for their PowerFC. The shop ran a multimeter debug and replaced a few capacitors and resistors. The unit now works and remains to operate correctly. Previously the unit would not power up at all (blank screen and no fuel pump). The original fault was caused by a mismatched wiring configuration which shorted out a few fuses and the PowerFC failed at this stage. Your last resort would be to try a local electronics shop to try and debug what is failed or damaged. I would expect a $150 repair bill to be about normal for this sort of work. The other option is simply to buy a new or used PowerFC.
Everything is fixable its just a matter of how much will it cost :D - ask your local mechanic/auto elec shop for a quote if you have toasted your PowerFC
My Hand Controller freezes at the Apexi Logo. Why???
When you use an incorrect model hand controller on a PowerFC unit the hand controller will freeze at the Apexi Logo. I believe this occurs as during boot up the hand controller sends a "hello,ping" to the PowerFC using a specific CRC function (or possibly a shared key based on the model). The PowerFC replies with a preset "shared key" to suit that unit, such as an rb26 skyline shared key. If you are using a different hand controller then the packet is scrambled or fails CRC and boot up fails, the result the Hand Controller stays on the Apexi logo. The PowerFC will still work, it just means that you can't use the hand controller. The most common "in the wild" occurance of this we have seen is the first generation PowerFC's 2.x 3.x 4.x and using newer model hand controllers. There are quiet a few version "variants" in the wild and below is a list of them. This is taken from my own "in the wild" experience and what's on the Apexi site. It is by no means a perfect model list and it could be wrong or have errors/mistakes.
Internal Apexi Model Name for Hand Controller
FCC NT First generation to suit Nissan
FCC FN Second generation to suit Nissan
FCC AD First generation to suit Nissan Djetro
FCC TS MR2 model
FCC TZ MR2 model
FCC SX Toyota Altezza/Lexus I think
FCC ZF RX7
FCC ZG RX7 Second Generation
FCC IH Honda Integra
FCC2 SX Version 2 for Toyota Altezza/Lexus
FCC2 JX Version 2 for Toyota Chaser
FCC2 DK Version 2 for Evo Lancer
FCC2 Version 2 general
FCC3 Version 3 general
FCC3 1JAT Version 3 Chaser Auto
The main product codes seem to be
FCC First Batch
FCC2 Version 2
FCC3 Version 3
Units that are sold as Version 3 seem to be the newer PowerFC and Hand Controller bundle in one price/package. Most people that have brought a new PowerFC in the last 2-3 years should have this bundle/package. The Hand Controller versions for these units should 5.x 8.x and so on. Units that are sold as Version 2 seem to be expansions of the Version 1 run but with more cars supported. This is likely to be version 3.x and 4.x under ETC, VERSION Version 1 or FCC is likely to be the first generation PowerFCs and may even say 2.x under ETC,VERSION.
The PowerFC also has an internal model or board number. My Skyline has FC-14B for its main board version. The main thing to note here is the sticker or product code on the PowerFC Shell. My skyline has ECR33. Other likely models would be GTR33 or SR20 and so on (basically the car or engine code).
The hand controller logo freeze seems to crop up when using an FCC3 on an FCC based PowerFC. Such as using as first generation R33 PowerFC and using a newer generation R33 hand controller. The common "in the wild" example is using FCC3 (sticker on back of hand controller) on a RB25 PowerFC (sticker on side of unit). This will not work, as RB25 PowerFC labelled units expect FCC NT instead of FCC3 so it will freeze and fail boot up.
Looking at the Apexi product chart for models we can see that the original run of Skyline R33 PowerFCS were known as RB25 on the unit itself. Its a little white sticker on the outside of the case. Newer generation R33 were known as ECR33 and this is present on the sticker also (in the same spot). So going from apexi's chart we can see that the original style RB25 PFC needs FCC NT. We can also see from this chart that FCC NT works on all of the first generation Nissan models. So if you can find an older style to suit any of the Nissan PowerFCs then this should work on RB25 PowerFC. Most suppliers dont stock the older versions cos they don't carry them anymore. Our main supplier Nengun.com has the following older style hand controllers
415-N001 Nissan Main Old Style
415-T001 Toyota Main Old Style
415-T003 Toyota Type B Old Style (not sure what this is for)
415-X001 Newer Style Hand Controller
So if you have 3.x 4.x then you should aim for the older style to suit your Car. if you have the newer 5.x then you should go for the newer X001 unit.
So for RB25 you should choose 415-N001 as 415-N001 is the first generation Nissan Hand Controller. If you have ECR33 you should choose 415-X001 as its the newer Nissan Hand Controller.
Airbag warning error light stuck on with PowerFC in my GTR. Why???
The PowerFC does not control, interoperate or do anything related to the airbag system in the Sklyine GTR. The airbag system is a complete standalone system and is run by itlself. If you do have the airbag light on in your Skyline GTR you can try the following to help (even with stock ECU);
BCNR33
How to reset SRS(air bag) light: Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS). Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine. If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer."
BNR34
Have your drivers door open, turn the key on to ignition and within 5 seconds press the door light switch 7 times. this will reset it.
Re: Apexy PowerFC
Сообщение MMX » 14 окт 2018, 10:02
Unsupported Features / Hacks
Airtemp sensor on unsupported car?
Some PowerFC's have support for the AirTemp sensor under MONITOR but the car itself does not utilize a factory air temp inlet sensor. I attempted to hook up an airtemp sensor on my ECR33 PowerFC and fried the powerfc and damaged a sensor on my car. The concept was to look at which pin on the BNR33 PowerFC the air temp sensor was connected on and then try and replicate this on the ECR33 PowerFC. I tried this and it did not work, I tried an adjacent wire and it fried the PowerFC. It has since been fixed and all is working but I do not recommend you try to get this working. It may work out costly like it could have been in my case.
Boost display without the Boost Control Kit?
By default as the PowerFC will not show boost pressure as it has no method of reading it in via the stock ECU loom. If you purchase a suitable map sensor and connect it to the PowerFC boost control kit port then the hand controller will display boost pressure. The boost control kit uses a Denso map sensor which is part #DPS 310 2000a - Denso 949940 6270 5V and the wiring loom cable/plug can be brought from Apexi which is around $40 AU. The cable is listed as the 3pin boost control harness. Nengun has this listed under Electronics -> Apexi -> D Jetro Option Parts
Alternatively below is the pin out diagram for the Boost Control Kit port. This is for the 3 pin version only. I am unsure of the pinouts for the 5 pin version.
1 = Voltage+
2 = Signal
3 = Ground
I have done this on my car and it works correclty. I used the boost control kit harness ($30 new) and the Boost Control kit Map sensor. Connect them up using the supplied plugs & loom and plug it into the PowerFC Boost Control kit port. You don't need to enable the Boost Control Kit (under ETC, FUNCTION SELECT) for it to display boost and for BOST to work in ETC, SENSOR SW/CHECK
What does the PowerFC look like inside?
Here are some pics of what the Apexi PowerFC looks like inside. These photos are just for curiosity sake
This is inside a Skyline GTST RB25 PowerFC
This is inside a Skyline GTST RB20 AP Engineering PowerFC
Note: the expansion slot used by an adapter
This is inside an Skyline GTR RB26 PowerFC
This is inside a Skyline GTR RB26 PowerFC
Note: The expansion chip (like the rb20 ap eng) and the alternate main ecu
Please note: The "FC Pro" sticker does NOT mean this is a PowerFC Pro unit.
This means the unit can be connected to Apexi's Power Excel software. See - What does the "FC Pro" sticker mean? Why is it there?
Can you reflash the PowerFC with new code and/or different versions of the Apexi code?
The newer model Apexi PowerFC's have a different model NEC processor and also feature an onboard connector, possibly for reflashing internally by Apexi staff and / or authorised dealers etc.
If you open up your PowerFC unit and you see a processor which has;
NEC Processor: 78P3 CPU
Not reflashable
NEC Processor: 78F4 CPU
Reflashable
For more information on this check out the thread on the RX7 forum by FastHatch. He has done some extensive research on this and found that they are reflashable and can be altered providing you know how. Some good news possibly :)
Are there any cool custom hacks, hand controller holders, DIY rewiring you can do?
There are a few custom mods you can do some clever, some not so clever. The pictures contained below are mostly taken from the Rx7 forum and other forums found in google. Some show some clever hand controller holders you can get, generic mobile phone holders should work fine. See below pics for some cool ideas:
Re: Apexy PowerFC
Сообщение MMX » 04 ноя 2018, 11:06
Is there a replacement hand controller screen?
As an unofficial replacement hand controller screen you can check out here for a suitable 128x128 backlit LCD. It even comes in different colours to be cool. I am unsure if this model works OK with the apexi hand controller.
I have tried using the Sieko screen on my personal hand controller work bench and it did not work.
The screen simply refuses to power up and light up. Try it yourself if you wish - you might get lucky.
Can I use 95ron octane fuel (non premium)?
The PowerFC itself does not know the octane count of the fuel you use, that is it will not know if you put in 95,96, or 98ron (and so on...) What is likely to happen if you put in lower octane fuel is that it will detonate lots more, commonly known as knocking. This is completely unsupported and excessive detonation can make your engine go bang, using 95 ron or low octane fuel is NOT a good idea
!!! Temporary IGN/IJN Adjust values are reset at car power off. You MUST re-enter this each time you restart the car (if you use say low octane for say 2 days and need to turn the car on/off) !!!
There are two steps you should take when using lower octane fuel.
Retard the ignition Timing to prevent detonation
You can do this by going into [SETTING], [IGN/INJ] and then on the left hand side you will see IGN correction. You can then slowly decrease the ADJ value to a negative value in small increments. It would take out around 7 degrees (so -7) then drive around and see if it knocks. If knocking levels are normal (around 20 odd) then its fine and keep it that.
Richen the fuel up to prevent detonation
You can do this by going into [SETTING], [IGN/INJ] and then on the right hand side you will see INJ correction. You can then slowly increase the ADJ value to a positive value in small increments. If you see black smoke then you have richend it up too much, take some out. If it doesn't idle properly (ie coughing or spluttering) you have richend it up too much, take some out.
If you do both of those when you put in lower octane fuel then the car should run fine and should have minimal knocking. You should only use this sparingly as its still much more likely to knock with lower octane fuel. Whilst you are doing this unsupported function you MUST watch the knocking levels on the hand controller at all times. MONITOR, 1 CHANNEL, KNOCK and watch the bar graph. Press UP to get a digital readout figure (highest value). Anything above 60 is bad and can be causing damage.
IE: Don't use this every day. If you are out of fuel, then put in say 20 lites of 95ron (or crap fuel) and find the nearest premium outlet. You should not use lower octane fuel and octane booster as a comprimise for premium 98 ron fuel, instead it is much safer to use the above procedure.
Poor mans antilag??
Whilst there is no official Apexi plug in Anti Lag and Datalogit Antilag is broken you can do a "poor mans antilag". This is at zero cost and is merely amusing and a bit of fun, I don't think it does any good (and might not be safe).
1. SETTING
2. IGN MAP
3. Change the top row (row P01) to be all zero's (the number 0) for IGN timing.
4. Drive around and listen to the car pop and backfire on gearchange
This is because on gear change the AFM momentarily drops its air when the throttle body closes so AFM drops into load point P01 (most times, not %100). So the result is, the engine drops to 0deg IGN timing for a split second and it pops and backfires on gearchange, race car style. This may not be safe and suitable for ceramic exhaust wheel'd turbo cars as it could cause exhaust wheel failure from heat. Logic says it should bring on boost a bit quicker but it doesn't appear to do squat. Traditional anitlag backs off timing on gearchange and dumps fuel, but keeps the throttle nailed so keep exhaust gas flowing.
Anyway try it and impress your friends. I have this applied to my car still after about a year and everything is still fine - standard turbo is still in tact etc
Boot up diagnostic??
There appears to be some sort of internal debug, check sum or something at boot up.
1. Press and hold UP on the hand controller
2. Turn the car ON
3. See what comes up on the hand controller
Email me what results you get, I'd be interested to see what comes up.
Email me what version PowerFC you have from ETC, VERSION and what is displayed.
Can I have a lumpy 'cammed' idle?
For some bizzare reason you may want a lumpy 'cammed' idle. To impress your friends, for kicks or to sound tough on the streets at the traffic lights against that Clubsport R8. When the PowerFC runs it's idle loop it plonks itself onto cell 2x2 and stays there. You may notice if you dial in more or less IGN timing on that cell, that it is ignored for idle loop. That is, it will always run 15deg IGN timing no matter what you dial into that cell. An alterate "hack" is the following
1. Turn car ON
2. SETTING, IGN/INJ
3. Press DOWN 1 time
If you observe lumpy idle then note the number ie: -1 If you don't observe lumpy idle, press DOWN again. Keep repeating until you get lumpy idle, don't go past -3 or -4 it's too much. Now with that number in mind do the following
1. Turn car OFF
2. Dial back the Crank Angle Sensor whatever number you had in IGN/INJ Adjust, so if you had -2 dial it back 2 deg
3. Turn car to ACC
4. Edit the IGN map and shift every cell UP whatever number you used in #2. So if it was -2 then add 2deg timing to every IGN cell on the map
3. Turn car ON
4. Observe lumpy idle
This is by no means a supported feature and it might not even be a good idea. It's just something I observed and thought of with my car. By all means try it but do so at your own risk, if you blow stuff up or cause problems then its your own fault, you were warned.
Ford Falcon XF Throttle body with the PowerFC
Some owners upgrade the standard Skyline GTST single throttle body to a larger unit. A common donor for this part is the Ford Falcon XF Throttle body. The problem with this swap is the throttle body opens backwards on the XF unit so the TPS signal wont match. You need to use the Nissan RB30 TPS sensor which is the same as the standard skyline one and works with the XF unit.
A discussion thread on this topic can be found at: http://www.skylinesaustralia.com/forums ... pic=151259
Piggybacking the PowerFC with another ECU
There are some cases of people piggybacking the Apexi PowerFC onto other ECU's and running both. Presumably this would be in the case of an auto car that needs auto shift logic control. We recall that keir wilsons drag car at one stage had a Motec ECU piggybacked with a PowerFC. I believe this was for knock sensor display/suppport. There was an article in autospeed about it. I don't see why anyone would want to piggyback it with another ECU, but it could certainly work.
I want to go EPROM/Firmware hacking, Tell me how
Whilst I cannot help you directly someone (Kashima) on the Internet has done some exstensive work on the EPROM and Firmware on the PowerFC. He covers changing the EPROM chip on the hand controller, the binary dumps for the maps, the pinouts for the various sockets and even board/chipsets used.
PowerFC Firmware: http://www.kaele.com/~kashima/car/powerfc/
PowerFC Adapter, Apps: http://www.kaele.com/~kashima/car/pfcadp/
Kashima is very clever in this area - you should read some of his pages if you are intersted in his work etc. There is another guy who is pretty darn clever in terms of the PowerFC and how to play with it - he is Goblin on the Rx7 forums. He originally wrote the "Hacking the PowerFC" documentation and it goes into detail about the datalogit system etc. A bit controversial sure - but worth a read and some interesting things to note in there too.
Replacement Air Temp sensor?
Some members have been looking for a replacement air temp sensor to avoid heat soak or show faster changes in temperature. Some of the guys from the Rx7 club have found a suitable sensor and are trying it out.
They believe it should be a direct swap and work really well with the PowerFC standard AIRT sensor control.
http://www.compsystems.com.au/Downloads ... SA5ATS.pdf
The company is in Victoria which is handy. More news when they test it out and get it working correctly.
USB Inline serial port debugger?
A very clever eletrical engineer from the RX7club.com has connected up an inline USB debugger. He is using this to debug the PowerFC protocol in real time and possibly add in your own events/codes etc. Worth checking it, as its a very neatly done & clever hack to the hand controller (and it works too!)...
You'll also note he's changed the surface LEDS to bright blue...
Well worth a read & check out what he is upto...
RX7Club.com Thread on USB Inline debugger
Re: Apexy PowerFC
Сообщение MMX » 11 ноя 2018, 11:08
Datalogit System
What is Datalogit?
Datalogit is a 3rd party system for the Apexi PowerFC. The system/kit includes of a dongle box and software. The dongle box plugs into the Hand Controller port on the PowerFC and the software runs on a laptop connected to the dongle box via a serial cable. The dongle box has a Hand Controller port so you can keep the normal Hand Controller connected whilst using Datalogit. The Datalogit dongle box translates the PowerFC signals from the Hand Controller to signals to the COM port on the dongle box which are used by the software running on the laptop.
What does Datalogit do, is there a feature list?
The software has many features as to does the Dongle box. The dongle box has the following "external" features for use with the software. The Dongle box supporst Anti Lag, Boost Scramble and Wideband 02 Input. The software has the following items which are not accessible via the Hand Controller:
You can download maps to your PC and save them.
You can set the fan temperature turn-on value to below lower then 60deg.
You can set the millisecond values for the engine flash light for AFM, INJ, KNK levels.
You can access and control the air temp correction table.
You can adjust load map points by extended the airflow measure levels.
The follow tables/settings are also changeable
Inlet air temp fuel map
Water temp fuel map
RPM acceleration fuel map
Cranking Injector dwell map
Water temp versus boost fuel correction
Inlet air temp versus boost fuel correction
RPM Load Point table
AFM load point table
AFM voltage table
Ignition versus water temp correction
Ignition versus inlet air temp correction
Ignition dwell versus RPM correction
Ignition versus battery voltage correction
Ignition versus boost correction
Individual injector trim
Injector lag versus battery voltage correction
You can choose to log values from the sensor list that you see in "SENSOR/SW CHECK" and also the ones in MONITOR so you can log some of the engine items that you can't normally view in MONITOR but are visible in "SENSOR/SW CHECK".
Once of the most useful features I have found is the "Advanced Logging" system which logs a selected "item" and plots it's min/max/avg values on a map tracer field. So you can log KNOCK against a map tracer view and it will plot min/max/avg KNOCK for each map tracer cell in real time. This allows you to quickly identify which cells are knocking more than others, so you can adjust the timing for that particular cell. Below is an "Advanced Knock" watch that was done for a quick run around the block in my ECR33 RB25DET Skyline. You can quickly see which cells are knocking more than others, so I would easily know which cells I could afford more timing and other cells where I would need to take out some timing due to excessive knock as an example. This method of loggin and map trace is aviable for any of the loggable items.
If you wish to see a log run or an example of the data logged then please click here to download an Excel Spreadsheet of a run my car did just around the local block.
What does the box look like and what's inside it?
The dongle box has a very simple circuit diagram to translate the communication between the PowerFC and the software. The PowerFC protocol has checksumming and error correction in the protocol so I assume this is what the PIC processor is used for. The Dongle box also analog and switchable inputs which can be used for 3rd party tools (as listed above). Below are some pics of the Dongle box. Note: I do not proomote disassembling or reverse engineering the box but merely took some pics for "curiosity" sake.
Do you really need to have it or is the Hand Controller OK?
Datalogit is not required for normal use and even tuning. Things are easier with datalogit and you can much easier (as addressed above) when correcting knocking and other tune based issues as you can quickly find what cell has the min/max/avg of any value. It also allows you to save your tune to a .dat file in case you reset your unit or it gets damaged somehow. I found it very handy to plug datalogit into a laptop and use the laptops video out to my built in TV screen to preform Advanced Knock log whilst driving around, very helpful but certainly not required. The Datalogit kit is required when you move to a Q45 airflow meter or other unsupport airflow meters as you need to alter the airflow voltage ramp table. Selecting VH41 from the menu does allow it to run but it usually needs to be fine tweaked via the voltage ramp table.
Where did you get it from and can I buy one? What is support like?
Datalogit can be purchased from http://www.fc-datalogit.co.nz (Brand new its about $500 AU) or from a 2nd hand user on the forums or even a group buy. There is a small delay from the time of purchase, to receiving the Datalogit box and software. Support is formed as an open community user group as opposed to a phone number or online web page. Latest versions of the software are also available in the user groups for download.
Re: Apexy PowerFC
Сообщение MMX » 18 ноя 2018, 10:05
FC Hako Cable
What is FC Hako?
FC Hako is a 3rd party cable solution for the Apexi PowerFC.
The system is a dongle box cable that you can plug into your PowerFC (via hand controller port) and into a Laptop/PC.
The FC Hako solution is a cable only solution and once connected you can use any suppored software as you please.
The solution is a cost effective, leight weight tuning interface to let you tune (and log) your PowerFC from a computer.
FC Hako has been developed from scratch using the NEC data protocols the PowerFC uses and has been developed in Australia.
FC Hako works will all PowerFC units and a range of software options to suit your tuning and logging preference.
What does FC Hako support/is there a feature list?
FC Hako is a cable solution and you can use the software of your choice, so it's feature list is endless.
Supported software with FC Hako
Co Pilot
FC Tune
FC Edit (Datalogit)
FC Pro (US and Jap versions)
The FC Hako box also includes dual ADC (analog to digital) inputs for wideband sensors etc
What does the box look like?
The FC Hako is simple in design as per the below photos
FC Hako is not essential for every day use however it can make most things easier, quicker (and cheaper if paying for labour).
As you can use your preferred software option, you can use what suits you the most (or the tuner).
FC Hako is a great way to spend time tuning your car, adjusting complex tunes, getting down to the nitty gritty (instead of using the slow hand controller) or performing detailed tuning such as wideband 02 tuning and aggressive ignition map tuning.
Even a novice user with the right tools and some basic car knowledge and time can improve on their already present tune to get more performance and a better overall car with some basic data analysis and the right software with FC Hako.
FC Hako can be purchased from their website or on ebay under their online store
FC Hako retails for $175 AUD and is avaiable for shipment via their website or ebay at time of purchase.
Support is provided locally and you can contact them before or after sales via their website. fc-hako.com
Both John and David (developers of FC Hako) are experienced electronics engineers and also enjoys cars as a primary hobby so their interest is the same as yours - Cars & getting the best out of them - like yourself.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 2 гостя
